Bad O2 sensor - (short thread)
Old Jul 13, 2004 | 05:26 PM
etxxz's Avatar
@ slide or die @
Yeah, my previous post was too long, hell...i woulnt have read it myself.
I F'd my O2 sensor and was wondering if there is an alternative to getting the $136 O2 sensor from my dealership. Cheaper universal internet O2? I could install, i just need the part but first i need to know where to get it from. HELP ME PLEASE??
Thanks all,
Luis.
Old Jul 13, 2004 | 08:52 PM
Seotaji's Avatar
you can get one from autozone or advance auto, as they sell both OEM and generic.
the generic ones are cheaper, but you'll have to make your own connector as they only have bare wires at the end.
it's easier and faster to just get the OEM one from a discount parts place.
Old Jul 13, 2004 | 09:31 PM
Strannik's Avatar
http://www.acuraautomotiveparts.org/ or I looked it up for 2000 TL here:
http://www.trademotion.com/partlocat...00&catalogid=1
Old Jul 13, 2004 | 10:29 PM
etxxz's Avatar
@ slide or die @
cool thanks for the tip
strannik, i got a '99...first link doesnt have O2s and in the otherone, those say 00+...im sure the're the same...can anyone confirm?
Old Jul 13, 2004 | 11:33 PM
Pure Adrenaline's Avatar
Dragging knees in
I just got a primary O2 sensor, new OEM, for 71.xx shipped from Tim at www.honda curaworld.com (delete the space).
If you have AIM, shoot him a message at Honda curaworld (delete the space again).
He's a great guy to work with. Good luck.
P.S. You don't want to use an aftermarket O2 sensor, as that will void your ECU warranty.
Old Jul 14, 2004 | 08:57 AM
Strannik's Avatar
Sounds like Pure Adrenaline found the best deal...
Old Jul 14, 2004 | 05:29 PM
etxxz's Avatar
@ slide or die @
PURE, i searched their story but i didnt find it...i added him to my AIM list and he wasnt online so i sent him an email and ill just wait for it. Thanks bro, now, does this senosor come with the wiring and the conector and all so that i just have to plug and screw it in to solve my engine light problem?
Old Jul 14, 2004 | 06:35 PM
Dragging knees in
He doesn't list all the parts on the web site. Most of the times, you will have to ask him on AIM or via E-mail. He's only on AOL during work hours (usually 7 AM to 5 PM EST).
If you wrote him an E-mail, expect a reply very soon. He's easy to get in touch with.
For my O2 sensor, yes, it did come with the sensor itself, wiring, and the plug adapter. It also comes with the 2 white click-in holders that you plug into the black mounting plate. It's held in by one screw (10mm) and I recommend you use a wretchting wrench because there's not much room in there.
You can access the plugs from the top of the engine bay. You just have to locate it (it's between the engine block and the firewall); it's not hard. Unplug that first, then take off the mounting bracket, then unscrew the O2 sensor. After taking out and putting the O2 sensors 4 times (had to check the old one a couple of times for some testing), I found out it's the easiest way to do it, since the wires twist and tangle up. And reverse the procedure to put the new one in.
If your MIL only has one code (O2 sensor-related failure), then yes, it'll solve your problem. However, the MIL will stay on since it has stored the trouble code. I recommend that you unplug the battery before you start replacing the sensor, and by the time you're done with all the work and hook up the battery, the stored code will be erased. If it didn't work, just leave the battery unplugged overnight. Just have your radio anti-theft code handy.
Good luck and make sure the car has been sitting for about an hour if you drove it prior to the work. I didn't wait because patience is not one of my virtues, and I got burned twice on my left arm from the damn transmission.
Old Jul 14, 2004 | 09:08 PM
Hornda's Avatar
check your local junk yardS! who knows i might have one at mine
Old Jul 14, 2004 | 10:56 PM
etxxz's Avatar
@ slide or die @
Its bad enough getting burned once...
Yeah, if this dud give me a price under 100, or 70like you said, ill definitely buy it. Thanks broda.
Does anyone know any reasons why this O2s go bad?
Old Jul 15, 2004 | 01:49 PM
Dragging knees in
Well, my first guess at why my O2 sensor died was because it was probably defective from the factory. It was slowly dying, and it was just a coincidence that it finally took its own life after I put the headers on. O2 sensors generally last a long time. No reason why it should die at 24k unless it was defective.
At any rate, that's just the cost of modifying your car. I'm just glad it was only an O2 sensor, not anything more serious that would've cost a lot of money to fix.
Runnin really rich could also kill an O2 sensor when it gets clogged with unburned fuel. The heater circuit is probably the first to go in this case, since it sits on the outer edge and is more susceptible to damage from running way rich.
Old Jul 16, 2004 | 12:59 PM
etxxz's Avatar
@ slide or die @
blows...
how about minor impact?
Old Jul 16, 2004 | 08:08 PM
Dragging knees in
What, like dropping the sensor on the ground? I don't think that would do any damage, really. Have you ever broken apart an o2 sensor? Everything looks pretty sturdy inside. I think you would have to slam the shit out of it against a concrete floor or something to break it.
Old Jul 16, 2004 | 11:39 PM
etxxz's Avatar
@ slide or die @
hmmmm...im still trying to figure out why mine went bad...i got 70kmi on the '99, and it went bad right after the header change. I did run the car for a minute or so withought the cat/exhaust, right out of the downpipe but the O2 wasnt plugged in, it was under the car, not hanging but in a tight space so it woulnt fall. It was plugged after i finished.
By the way, i moved the car a bit withought the cat/ex and it was LOUD AS HELL!!! i felt like i had 2000hp and was ripping thru 12000RPM on a drag car.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
ibGTV
Sep 28, 2015 03:40 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
