Axxis Ultimate Pads If Your Interested In Them Or Other Pads Look!!!
I was doing some research on many many different brake pads out there and was getting some mixed reviews but after finding a link on (believe it or not) the Mazda Miata site I've got my answers!!! This board should have something like this but I don't think anyone uses there TL for real track use but Miataz are always there... ANYWAY HERE'S SOME INFO FOR EVERYONE!!!
THIS IS A QUOTE FROM THERE BOARD...
AXXIS Ultimate Brake Pads
Applicable to: '90 - '97 1.6 liter 1.8 liter
Axxis pads billed for use in street and light track applications.
Scott @ RoadsterPerformance.com recommended these when it came time to replace my Porterfield R4-S pads. My experience with the pads is much the same as found in Ben Reyes' review. In short, the pads work exactly as billed. Between some aggressive street work and a two-driver track day, the pads just did not give up. When cold, they aren't noticeably different from the OEM compound, but they are markedly better as temps increase. When hot, they bite nicely; not quite as hard as a "true" racing pad, but harder than the R4-S, and most decidedly harder than stock. They also seem to have better longevity than the R4-S as well, not showing the crumbling that is typical with the Porterfields.
...And if the track performance wasn't enough, the dusting characteristics are wonderful to boot. They dust quite a lot more than stock, but somewhat less than the Porterfields. What impresses me most, though, is the quality of the dusting. With R4-S', I had to SCRUB the wheels to clean the dust off. Not so the Axxis Ultimates. I'd say that ~80% of the dust simply washes off with the hose, and the rest comes off with just a trivial swipe of a rag. I haven't seen another pad compound that can touch these for hot and cold performance, durability, dusting, and price. A great deal!
THIS REVIEW IS GOING TO HELP YOU TOO TIM
I've been looking into the PORTERFIELD'S OR THE ENDLESS OR THE AXXIS OR THE AEM PADS trying to come up with the real answer and there it is!!! AND the reviews keep claiming the same thing over and over!!! If you want to improve your braking A LOT and you don't or can't pay for the big brake kits, the Axxis Ultimate pads are very cheap and well worth the $$$, weither you keep the stock rotors or replace them!!! SORRY FOR THE LONG POST BUT IT'S WORTH IT!!!
Also plz don't edit this..... this site also tells you how you should brake in your NEW pads when you get them.
http://www.carbotecheng.com/faq-pad-q3.htm
This is good info that everyone should have!!
SORRY ONE MORE QUOTE ABOUT AXXIS ULT. FROM THAT SITE...
Performance brake pads billed as dual purpose for street and track use.
I read about these pads on Roadster Performance's web site and thought I'd give them a try to improve my Miata's frightening wet braking with the OEM pads. I also knew I'd be attending the Thunderhill drivers school. I ordered the pads and put them on in early January.
They leave a lot of black dust that easily washes off and they tend to squeak around town. But wet braking is vastly improved over OEM pads, judging by my seat of the pants (no more of that scary delay until the pads bite the rotors). At Thunderhill, the instructors asked if I had ABS. No, just fabulous modulation at incipient lockup. No fade either in repeated high-speed braking. Two long days at the track used up about a third of the pad material on the front, but didn't appear to chew up the rotors. Rear pads appear to have at least 90 percent remaining. I'll definitely buy them again.
DOESN'T CHEW UP ROTORS + GREAT WET BRAKING!!!! AGAIN THIS IS WHAT WE BUY PADS 4!!!
THE MIATA SITE http://www.miata.net/products/perform/axxis.html
THEY HAVE ALL THE PRODUCTS LISTED AND IF YOU'VE PURCHASED THEM YOU REVIEW THEM!!! VERY SMART!!!
WE SHOULD DO THAT HERE!!!
ACTUALLY FROM THAT SITE AND MANY MANY REVIEWS OF THE AXXIS PADS PEOPLE ARE SAYING THERE "STOCK" ROTORS WERE FINE??? I ALSO THOUGHT THAT THE AXXIS PADS WOULD EAT UP THE ROTORS TOO (that's why I did so much research) but it seems like they don't!!! AND THIS IS FROM HEAVY TRACK USERS AS WELL!!! THAT'S A VERY IMPORTANT POINT!!!
with a light car the pads are good! with a heavy car like ours the pads SUCK! they over heat fast and get spungy! the factory pads are better!, if you want a good pad that work well with all sorts of driving the Green Stuff is the best. low dust, takes a beating, and is track worthy. i ran about 6 laps at road america and switche back to the factory pads because the axxis was too spongy and couldnt slow me down fast enough once the rotor was hot. the factory pad was able to over and over. the green stuff is alot like the factory pad but it is alot less dust
OG
I've been using the Axxis pads on my TL with stock rotors since 5000 miles. They are WAY BETTER than stock and do not eat up the stock rotors..... They have been on my car for about 4 years now.
'99 Acura 3.2TL
i read the bed-in instructions for the pads and it says to brake hard 6-8 times and let the car sit overnight.
it gets in conflicts with the rotors break-in instructions.. i was told not to brake hard for the first 200-500miles..
what do i do
@cUr@-TL
what do i do
@cUr@-TL
Originally posted by BFOR3
I know you have experience with them but ALL I'VE HEARD ABOUT GREEN STUFF PADS IS THEY AREN'T WORTH A DAMN!!! They blacken the rotors really easily and then that has a tendancy to warp them???
08_UA7_Gr33k
02-11-2016 02:17 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
