axle help please
axle help please
couple of things -
I did my drivers side axle yesterday and now my ABS/VSA/! lights are on? everything runs well and seems right. What did I miss?
Also - while I had the axle nut sockets on loan from the car parts store i decided to check my passenger side axle which I did a few months back and saw something I think might be bad - The plunge end (not the end by the steering knuckle, the tranny end) - With everything tightened up I can still grab the end and move it out enough to see the splines from under the car? It doesnt come all the way out of the tranny, but probably a good inch of spline is visible. I can push it back in so it is snug but it also can just be pulled back out again. What gives?
Thanks for your help!
You're either not getting it seated all the way back in the trans, you could have a weak or missing snap ring that holds it in the trans, or you could have an extra snap ring stuck on the axle that's keeping it from fully seating. You could also have an axle that's a little short.
TLer Trash was right! unfortunately i had to pull the whole thing out but it has no retainer ring on it! i took the one of the old axle and used it. Now - anybody know what i did to get the triad of lights on, on my dash? thanks again guys!
On the outer cv joint, about 10mm outboard of the boot, there should be a toothed wheel about 4" in diameter. It will have teeth about 2mm wide and 5mm high. The wheel speed sensor "counts" the teeth as the wheel rotates to give the ecm/bcm wheel speed. These dimensions are from a memory almost as sharp as Abe Simpson's.
It's possible that the seal was damaged during axle installation, or when it was moving around in the trans while the snap ring was missing.
Jul 16, 2017 07:33 AM
