axle help please
Old Nov 1, 2009 | 12:17 PM
chrismeoli's Avatar
axle help please
couple of things -
I did my drivers side axle yesterday and now my ABS/VSA/! lights are on? everything runs well and seems right. What did I miss?
Also - while I had the axle nut sockets on loan from the car parts store i decided to check my passenger side axle which I did a few months back and saw something I think might be bad - The plunge end (not the end by the steering knuckle, the tranny end) - With everything tightened up I can still grab the end and move it out enough to see the splines from under the car? It doesnt come all the way out of the tranny, but probably a good inch of spline is visible. I can push it back in so it is snug but it also can just be pulled back out again. What gives?
Thanks for your help!
Old Nov 1, 2009 | 02:06 PM
gold2003tl (90)'s Avatar
2003 TL-p
make sure the spindle nut is tight, front is 181 foot pounds and the rear are 134 foot pounds i believe.
Old Nov 1, 2009 | 02:10 PM
chrismeoli's Avatar
it is, the shaft is not moving, just the plunge end at the tranny.
Old Nov 3, 2009 | 01:30 PM
TLer trash's Avatar
You're either not getting it seated all the way back in the trans, you could have a weak or missing snap ring that holds it in the trans, or you could have an extra snap ring stuck on the axle that's keeping it from fully seating. You could also have an axle that's a little short.
Old Nov 4, 2009 | 01:40 PM
chrismeoli's Avatar
TLer Trash was right! unfortunately i had to pull the whole thing out but it has no retainer ring on it! i took the one of the old axle and used it. Now - anybody know what i did to get the triad of lights on, on my dash? thanks again guys!
Old Nov 4, 2009 | 07:09 PM
TLer trash's Avatar
Take a close look at the tone ring on the driver's side axle. Is it beat up? Does it have any cracks or missing teeth? Is there a tone ring at all?
Old Nov 5, 2009 | 08:43 AM
chrismeoli's Avatar
oh jees, whats it look like? whats it do?
Old Nov 5, 2009 | 11:32 AM
TLer trash's Avatar
On the outer cv joint, about 10mm outboard of the boot, there should be a toothed wheel about 4" in diameter. It will have teeth about 2mm wide and 5mm high. The wheel speed sensor "counts" the teeth as the wheel rotates to give the ecm/bcm wheel speed. These dimensions are from a memory almost as sharp as Abe Simpson's.
Old Nov 5, 2009 | 12:19 PM
fsttyms1's Avatar
When you removed your axle did you unplug the sensor or pull to hard and rip the wire? That would be the first thing i would look at
Old Nov 5, 2009 | 12:59 PM
chrismeoli's Avatar
do you mean the sensor on the steering knuckle? by the brakes?
Old Nov 7, 2009 | 08:07 AM
davejko's Avatar
8th Gear
The ABS sensor probably isn't seated all the way down. Take it out, clean it, and apply a small amount of lubricant and re-seat.
Old Nov 11, 2009 | 08:12 AM
chrismeoli's Avatar
i am also noticing a small amount of tranny fluid leaking from where it meets the axle. Can i just loosen the axle nut on the knuckle and bang it in tight?
Old Nov 12, 2009 | 11:12 AM
TLer trash's Avatar
It's possible that the seal was damaged during axle installation, or when it was moving around in the trans while the snap ring was missing.
Mike734
Dec 10, 2021 01:25 PM
jblessing
Aug 8, 2018 09:43 PM
Jul 16, 2017 07:33 AM
polish_pat
Sep 30, 2015 12:22 PM
