automatic sunroof in the process!!
'99 Acura 3.2TL
hey guys i finally figured out the automatic sunroof diagram that bebber made and i decided to wire everything (the relays, timer, etc) that i could out of the car.. cuz it's in the shop being painted. and when i get my car back, it's gonna be like a plug and play..
i tested the "system" with a 12v battery and a few lights, and it works! all i'll have to do when i get my car back is connect the grounds and the +12v's where they need to be connected and everything should work!
i'll keep you guys updated cuz i know a lot of you wanted to do this.. it's very simple when you understand the diagram!!
@cUr@-TL
@cUr@-TL
@cUr@-TL
@cUr@-TL
Didn't have bebber's diagram though. How much did u get the 528 relays for? Also you were able to break the circuit with the tilt button righT? so you can stop it in mid process.
'99 Acura 3.2TL
Originally Posted by Bxscig
Yeah, i figured it out also but I am sitting on my ass waiting for the damn parts. I know why most shops can't figure the sunroof out though, its because they go straight to the motor.
got the timer for like 25$..
and yes i can break the circuit with the tilt button
joganjani/Gold2kTL: on the 2nd gen TLs, you need to hold down the button until the roof is fully opened/closed.
with this modification, you will only have to press the button no need to hold it down. the sunroof will close or open automatically.
btw it's not my idea, it's bebber's idea!
@cUr@-TL
'99 Acura 3.2TL
Originally Posted by Darkshear
Austin did this with all 4 windows...
I would love to do it with the sunroof.
Get a DIY rolling and you will be God of the week
well guys i put everything into my car yesterday and it works!! my sunroof now opens/closes by itself! i love it!
im gonna try to do a DIY.. im not too good at that kind of stuff tho, but i'll try
@cUr@-TL
Sig Rho's Finest
holy sh*t yo, if you can get a DIY on this mod. screw god of the week. ill giva ya god of the month status!!!!!
who is austin and how did he do that to all the windows?!
Originally Posted by shogun
will the tilt button install it on my car!
Ok but guys will the tilt feature still work? My take on this is when the open/close button is pushed, the tilt button is converted into a relay that will simply interrupt the process of the sunroof from opening/closing automatically and will stop the sunroof from moving whenever you push it. If you simply push the tilt button when the sunroof is closed, it will simply tilt up like it always has...
is this correct?
is this correct?
booooo
is this correct?
is this correct?
huh??? will the tilt button install on your car? If you don't have a tilt button you can wire it to something else like a simple push button to stop the automation process.
'99 Acura 3.2TL
is this correct?
is this correct?
im in the process of making the DIY.. should be ready on Monday
@cUr@-TL
correct.
@cUr@-TL
@cUr@-TL
Another question about this mod. If the roof is tilted, you usually press the close button to bring it back down. Since you only need to push the close button for a second or two (less time that it takes to close the roof it were slid open) to close the tilt, does the timer still engage the motor to close the roof for 5 seconds or whatever (the time that’s used to close an open sunroof)? Wouldn't that hurt the motor to push against a shut roof for that long (I'm thinking long term, over the course of years)? Or is there a kill switch already built into the roof that stops the motor after the roof is fully closed even if the button is held?
'99 Acura 3.2TL
well guys, i think im done with the text/diagram part of the DIY.. all i need to do now is take a few pics to help visual people
the DIY should be available tomorrow evening!
btw, everytime i use my sunroof now, im like WOW! i cant get enough of it
@cUr@-TL
@cUr@-TL
'99 Acura 3.2TL
if u guys have any suggestions/corrections for the DIY email me at quebectl@infoteck.qc.ca
im not really good at stuff like that so there are prolly a few mistakes here and there, and i prolly forgot something
malayalee king: thanks for hosting the files!
@cUr@-TL
@cUr@-TL
mlody
12-04-2019 02:11 PM
Joe Avesyan
09-29-2015 03:57 PM
