Audio question but....
wanted to ask specific people who own the TL (99). I have a 5 channel amp, after market HU and a sub that I would like to install. Would there be any problems running the stock speakers through the new amp. I do plan on getting new door speakers all around but can't at the moment. Does anyone know offhand what the handling power is of the stock speakers. I'm sick of the stock Bose HU as well as the sub.
I'll post this in the Audio forum as well - I just wanted advice/answers from those who own a 2nd Gen TL.
Thx,
B
Thx,
B
the search button will be your best answer.
but just my thought in it, the aftermarket HU and the stock speakers, or the amp and the stock speakers, are running at totally different ohms and will not work correctly. if you change out your radio or use a different amp you gonna have to change out all your speakers as well.
but just my thought in it, the aftermarket HU and the stock speakers are running at totally different ohms and will not work correctly. if you change out your radio, you gonna have to change out all your speakers as well.
Yse you can run a aftermarket amp to them, but you will have to be carefull as to how much power you send thru them. Use judgment and listen for clipping and distortion
Originally Posted by fsttyms1
No they arent. The stock speakers work just fine with a aftermarket HU. In fact they sound alot better. (aftermarkets will sound better though)
really? wow, i've been misled. thanx for clearin that up...
I'll have to check thre specs of my amp and get back with you.
fsttyms1: Did you install your HU and amp yourself? How do you run the wires from the HU to the new amp? Did you have to "rip" everything up to place the wires?
Originally Posted by RickRoush03
ya but whats the power from the amp, an aftermarket HU puts out tops i have seen aroudn 25rms, if you put like my 5ch amp that pushs 70rms to each car speaker, you'll blow them out. would you not?
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
