Attn Comptech Spring owners
Old Nov 10, 2000 | 08:07 PM
JZ39's Avatar
Post Attn Comptech Spring owners
I just got back from my dealer who installed my springs on my CLS and there was a slight problem.....The inside edges of both of my front tires were completely bald!!
1. Has anyone else had this problem? (You can check by just cranking your wheel to the
right and looking at the inside edge)
2. What might be causing this?
The car was supposedly aligned as part of the install. Could the increase in negative camber be that significant that it would kill tires in 6000 miles?
I would appreciate it if you guys could check on your tires and post any findings. I did call Mike at Comptech and he said that the TL owners did not report this problem and also
talked about the possibility of camber adjusters.
2001 Black/Black CL Type S
Comptech springs, headers PIAA 19169 road lamps Solaris 9005 High Beams
http://albums.photopoint.com/j/AlbumIndex?u=1192826&a=8788545
Old Nov 10, 2000 | 09:10 PM
NSX4dr's Avatar
Original Member #81
Post
You got your car aligned when it was done, but if you hit a pothole or the such, that could knock out your alignment.......sorry for the bad news, you just have to keep checking on your car.....
Comptech exhaust
Comptech springs
custom air intake
18x7.5 Alstadts w/ 53mm offset
225/40/18 Kumho Ecsta Supras
153mph Top Speed
193hp @ the wheels....soon to be
250hp @ the wheels....13's here I come
Old Nov 10, 2000 | 09:19 PM
JZ39's Avatar
Post
Can the alignemnt be really screwed even if the car isn't pulling to one side at all? Doesn't this problem sound like a camber problem? Has anything like this happened to yours? More info--please.
Old Nov 10, 2000 | 10:20 PM
AcuraTL's Avatar
OG
Post
I've had the Comptech springs since May of 1999. My tires are wearing evenly. Even if you get an alignment, the cambers on our cars cannot be adjusted. You can either get a camber kit or have your alignment recheck. Toe-out could also cause the inside edge of your tires to wear out quickly.
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads.
My AcuraTL Homepage
Old Nov 11, 2000 | 05:54 PM
Shoofin's Avatar
Post
It is usually recommended to drive the car for a thousand miles or so after installing the springs/before taking it in for a wheel alignment. This way, the spring can settle and you get a more even alignment.. If you align the wheels immediately, the car settles based on your alignment then a lil while later the car settles, not good...not bad either, but I waited a month or so before doing my alignment, and everythings correct, so far(had mine on since sept '99)
Ed
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element, Inspire Tails
Pics of my TL
Pics of my Miata! Wadya think?
Old Jan 31, 2001 | 08:13 PM
TITAN3.2TL's Avatar
Angry
I am having the same problem with inner tread tire wear. I waited about a month after installing the Comptech springs and had an alignment. I have had the alignment and balance checked and they are both fine. I am a little frustrated by this. Do you think replacing the stock shocks would help? They will be two years old in May. Also, how do you adjust the toe?
This photo is "pre-mods"; "post-mods" photo coming......
1999 Acura 3.2TL
Black with Ebony
Bridgestone Potenza RE730 (size: 225/55ZR-16 on stock rims)
AEM Cold Air Intake and Bi-Pass Valve
Comptech Headers
Mugen Exhaust
Comptech Sport Springs
Comptech Swaybars
Old Jan 31, 2001 | 08:59 PM
TITAN3.2TL's Avatar
Post
Okay, I just got my alignment papers from my last alignment. The front left toe was .36 (-0.08 to 0.08 is the range). The front right was -0.23 (-0.08 to 0.08). The rear was in pretty good shape.
Can the FRONT TOE be corrected? And if so, why didn't the alignment shop CORRECT IT?!?!
1999 Acura 3.2TL
Black with Ebony
Comptech Headers
Mugen Exhaust
Comptech Swaybars
Old Jan 31, 2001 | 09:37 PM
AcuraTL's Avatar
OG
Post
The only thing that can be adjusted in our suspension is the toe in and out. Yes, your alignment shop can adjust your toe settings. I really don't know why they didn't do it. I've had my springs for about 25,000 miles now, my tires are wearing perfectly even.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by AcuraTL on January 31, 2001 @ ]</font>
Old Jan 31, 2001 | 10:50 PM
Guest
Guest
Posts: n/a
Post
you probably need camber kits
Old Jan 31, 2001 | 11:00 PM
AcuraTL's Avatar
OG
Post
If you lower your car with Comptech springs, you do not need the camber kit. Also, Titan's alignment readout states his toe is off, his wheels are basically poiting outwards (away from each other), that's why his inner tire is wearing out.
Usmcgrunt47
Oct 13, 2023 09:35 PM
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
CarlosILX13
ILX Performance Parts & Modifications
14
Jul 11, 2016 11:07 AM
