Atf dw1???
2003 TL-p
once my dealer switches over to dw-1 i will do a 1x3, they still have a stock pile of z1 they need to get rid of. dw-1 is compatible, and contains some synthetics and is a little bit thinner than z1. if all is well, it should be a step up from z1 and give some improvements.
Always Working In
I agree FirePR, I did a 1x3 today with type f and noticed a considerable difference. I have a slippery 1-2 shift that improved noticeably.
But yes the dw-1 is backwards compatible with the z1. It supposed to be a better fluid.
But with all of the recent posts about redline/amsoil fluids working better in our trannies, its going in in the next change.
Theres tons of threads on this. I would read up on it and make your own conclusion on what you wanna do from there.
2003 TL-p
bringin lead
just be aware that once you switch to those fluids, you probably not going to be able to go back to honda fluid. my rebuild tranny is still under warranty so i will be sticking to honda fluid for now. also keep us posted on long term usage of these alternative fluids, thats what matters, since any fluid may have a short term fix.
2003 TL-p
my current plan in to stay on honda fluid until my warranty is up, then slowly introduce some type-f fluid. maybe do a 1x3 with one quart of type-f fuild, redline.
gold2003tl. so you're saying on the next change, you'll run 2 quarts z1 and 1 of the type f fluid?
And with an '02 with 108k miles, last change was at 77k in 2007....would it be viable to run Amsoil/Redline at this point?
Unregistered Member
It's just a way to describe how much is being drained/refilled.
AxB
A=How many times to drain/refill.
B=How many quarts to drain/refill.
So, 1x3 is a drain of 3 quarts followed by a fill of 3 quarts.
A 3x3 is doing that 3 quarts drain/fill three times in a row. (With 5 minute drive in between.)
AxB
2003 TL-p
Id be a bit concerned about doing a tranny oil change at this point, since it been over 30k miles since the last change. I might do a 1x3 at this point, not sure if id stick with amsoil or redline. What condition is the tranny in, does it slip or shudder?
my next change will probably still be under warranty, so 3 quarts of z1 or dw-1.
Anyway, since it was replaced w/ basically a new/remanufactured to new trans, do I go by the initial 60k service or just go by the 30k?
Always Working In
Running whatever fluid you want is your preference. We're just tired of our shit trannies and trying to improve upon an already established basis from many members experiences, trials and errors.
Some people say dont run this ,dont run that which i think is total bs. There's alot of information going on on better than oem fluids that which still doesnt solve the mechanical problem with the trannies it helps improve the operating characteristics of them.
At 31k since your last change, i think its safe to say the fluid might possibly need changing. (i think i remember people on here saying after a rebuild its good to do 30k intervals.) I'm not a trans specialist but I'm reading up alot on this topic from Azine members experiences and just trying to see whats best out there.
Well Since AMSOIL puke out of my Tranny and the Z1 is Aging in terms of Oil Tech, Ill try out the new DW1 in my Next change of course it will need to be a 3x3. Ill post the Results Next Month.
2003 TL-p
Just got off the phone w/ Tustin Acura and they said the trans was replaced in June of 2006 with 70,192 miles. So I'm hoping it was replaced with the new material in the clutchpacks.....
I found it very interesting that the new DW-1 was cheaper than the older Z-1 at the dealerships here in Jersey. So cheaper and better for my tranny? Give me a case! ha ha
The trans holds almost 8 quarts of trans fluid. When you drain it 3 to 3.2 usually comes out. I would if your going to change it, just use all 3 of the same type. The new dw1 is supposed to be thinner and better so you can use that and mix it with what you have in it, or go amsoil. The purpose of a 3x3 is to drain as much of the old out to get as much of the new in. I personally on a aging trans would do a 1x3 and drive it a few weeks to slowly introduce the new chemicals/additives then do another, followed by another a few weeks later.
Speaking of fluids, i need to go get some GM Syncromesh FM for my trans today and change it
who is going to test seafoam trans tune before a 3x3????- which says it removes selenoid crud etc
and might be our savior!!
will call their tech guy Jim D this week and ask some questions
my 01 with 40 on rebuilt warranty unit- shudder/wave feeling as it shifts into 2nd, and now a slight thunk into 3rd
vpasla1
09-17-2016 07:24 PM
Skirmich
09-15-2015 06:41 PM
