Anyone Replace a Negative Battery Cable?
Old 01-21-2013 | 08:03 PM
MSG C5's Avatar
If so, any tips? I had an emergency battery installed two years ago at an out-of-state Sears Auto center. Today, my 2002 TL Type S went dead and when I checked the battery, I realized that the negative battery cable/post lock in size and looks a lot different than the positive cable/connector. Since I had the plastic cover over the battery, I never noticed this until now.
I'm thinking the techs at Sears either swapped out my cable or swapped out connector because I remember them telling me the original one was corroded. It looks really shoddy.
If it is the battery, I want to swap out the cable as well. Any instructional links or suggestions?
Thanks!
Old 01-21-2013 | 09:33 PM
jo3lo22's Avatar
i just did due to me relocating mt battery to the rear
Old 01-22-2013 | 09:42 AM
victus1's Avatar
I replaced all the positive and ground power cables under the hood with custom cut 0-gauge stranded wire because the originals were corroded. I got some terminals and soldered them on with a blow torch.
Old 01-22-2013 | 10:05 AM
fsttyms1's Avatar
You can buy premade cables at most auto parts stores. Take yours off and get the length and type to match what you need.
Old 01-22-2013 | 10:57 AM
ANC297's Avatar
Bonki' Ehrite!
Me too
Old 01-22-2013 | 02:23 PM
Skirmich's Avatar
I dont have 0AWG but rather 2AWG Negative (Seems both are Overkill for my Setup Anyway) I just have 0AWG for the Alternator > Batt connection on the Big3.
Its really simple to replace the Negative side of the Battery there are just 2 cables going out of the Terminal;
1 for the Trans
2 for the Chasis (In front of Batt)
If your handy you can do the work for pretty darn cheap using Audio wire and accesories from a local Audio Shop.
Old 01-28-2013 | 08:46 AM
MSG C5's Avatar
Thanks for the replies!
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 06:12 PM
Phambam12
09-06-2015 06:57 PM
Quick Reply: Anyone Replace a Negative Battery Cable?
