Anyone Pumping 89 instead of 91 gas regularly?
#81
Originally Posted by 03CoupeV6
It's 19/27 for the 99 and 19/29 for the 00+
#83
05 C230K & 09 135i 6MT
I just took the TL on a highway trip of about 200 miles. I filled it up before the trip 2/3 with 93 octane and 1/3 87 octane. It held 15.6 gallons before the click. I did not top off.
I then got on the interstate and set cruise at 60mph with the windows (on the passenger side lol) halfway down. No A/C. 51.7 miles later the needle had moved from being above the "F" line to even with it, so I decided to see how much gas it had used. I stopped at a gas station, started fueling. At $2.98, holding 1.34 gallons, it clicked. Again, I did not top off.
Then I did the math:
51.7/1.34 = 38.58mpg!
Since then, I've traveled 105 miles and it has moved 3 lines from "F". This is driving it really easy, though.
#84
#85
Well there is a margin of error, but the tank initially held 15.6 gallons, went some more, and held 1.34 gallons. The margin of error can't be a huge one. The car was getting 36 mpg at the minimum, and that's assuming a pretty big error.
EDIT: FWIW both stations were RaceTrac.
#86
Originally Posted by progz
Those are hybrid mpg. I don't think all gas station has the same top off sensor. IMHO the only way to get a good estimate of the mpg is if you go back to the same station and pump.
and why would you mix regular and premium?
#87
Happy 08 TL-S Owner
Learned My Lesson
After pumping the "cheap" $2.56/gal. 87 octane crap for 6 months, my 05 TL started to run terrible. Knocking on start up, hesitation on acceleration, etc. I knew it was the gas because that was a calculated risk I was taking by puming the lower octane stuff. So went to the auto parts store and got a bottle of octane booster and put in tank of 87 I had just gotten and within 1/2 tank it was running well again. As much as the $2.71/gal. gets me, I will NEVER pump anything but the premium 93 octane again.
Lession learned... And yes I see the sticker inside the gas tank cover and have read the manual together with posts on this site about using the manufacturer recommended fuel.
Just a warning from one hard-headed owner to anyone who cares...
#88
Joe Avesyan
09-29-2015 03:57 PM
