Anyone know how to remove the speed governor?
I was absolutely sure that our TL-S/CL-S's were "drag limited" based on the info from Acura brochures and websites. This weekend i was chasing some bikes down I95 in NJ and hit the limiter at around 148mph(it just cut off the gas on me)- WHAT GIVES?? the car felt like it still had TONS of power... i'm sure i couldve squeezed out 170, and with the new tires, 150 doesnt feel fast in terms of stability.
Nehow, does neone know how to remove the governor? Has neone done this on the CL/TL?
(no flames about high speeds please)
'02 Nighthawk TL-S
Comptech Springs / Comptech Headers
Alpine CVA-1005 Head Unit / Alpine CDA-7863 CD Player / Alpine G320 EQ / Alpine DVA-5205 DVD / Alpine NVE-N851A Navi / JL Audio XR653-CS 3-Way comps for the front powered by a bridged Alpine MRV-F407 amp / Boston Acoustics 5.5 ProSeries 2-Way comps for the rear powered by Alpine MRV-1002 amp / Dual 10" JL Audio W-6 sub powered by Alpine MRV-1005 amp / Two Alpine CHA-1214 CD Changers / 20% Tint all-around
__________________
'00 Nighthawk TL
Aem Short Ram / Comptech Sway Bars / Comptech Springs / Cross-Drilled Rotors / Pirelli SP7000 Tires / 35% Tint all-around
Pics of my TL and Fun/Crazy Pics
'02 Nighthawk TL-S
__________________
'00 Nighthawk TL
The speed limiter is set to 147 MPH and it does not cut your gas. I hit the stop speed (147MPH) and held it steady for about 1 minute. I have no idea how to remove the speed limiter, but if you find out, let me know.
I've searched through the service manual several times and it makes no mention of a speed limiter on the TL. I've seen models that were speed limited (some 5th generation Civics) and the circuit was listed in the service manual. At any rate I'm sure it used the VSS (vehicle speed sensor) so, unless you modify that signal, there is no easy way to defeat it. Before anyone goes and yanks the VSS harness at the tranny... I can tell you that your automatic tranny will lose its capacity to "think" (i.e. drive like $hit) and your VTEC won't work -- neither of which are conducive to high speed driving.
As far as I know the top speed of the TL is, in fact, drag limited.
2000 WDP 3.2TL non-NAV
AEM CAI
AEM CAI
'02 Nighthawk TL-S
__________________
'00 Nighthawk TL
If you had a CT header and had tires to the correct pressures, you may be able to squeeze 160 and a bit. But 170 is not possible - not enough hp considering the drag of the car. In stock form, I estimate a 155 top speed. BTW, an indicated 147mph is likely to be slower in real speed.
Originally posted by Gabriele:
The fastest I'll go......in any car...is about 90 mph. I would be scared to death to do 147!! Plan on getting alot of miles out of my baby - - can't imagine running it that hard.
'02 Nighthawk TL-S
__________________
'00 Nighthawk TL
Guest
Posts: n/a
That is a very fast speed.
I drive 100+ frequently and it's really not a big deal. The car certainly handles it well.
147 though is friggin fast. On a freeway with other cars around, it's friggin... well you said no flames so...
Anyway, I don't think the car is suppose to cut out on you. Check with the dealer and let us know what you found out.
This is interesting.
I had a Saturn that did that once. Thing is limited at 110... piece of junk. Well I was following a Maxima and an Altima through the middle of Houston at about 110 mph... I had just turned off my AC as the two cars in front of me were pulling away... and then all of a sudden my power just cut out on me. I let up on the accelerator... (it took it about 2 seconds to give me back power)and then jabbed it back down.. but by that time the two cars were already gone. So I have experienced that type of issue when hitting a limiter... even though it wasn't in a TL-S. Just so u know that it can happen.
170 mph - impossible in this car without perhaps 500 hp. Drag effects follow a square law - for every 20 mph beyond a certain point, it takes twice the power.
147 is about the top speed allowed for a VR tire.
The fastest I have driven on the street is an actual 154 in a modified 1985 Corvette I had. At 145, the low pressure outside the car pulled the frameless windows away from the weatherstrip, creating a roar that scared the bejeezus out of me!
I had two radar detectors, one facing front, the other back.
After about 2 minutes, I backed off and set the cruise for 100 and felt like I was loafing along.
Rage On!
2002 TL-S w. Comptech header/exhaust
SSR Integral A2's
17x7 45mm offset
Pirelli P7000 (Summer) 215-50/17
Rage On!
SSR Integral A2's
17x7 45mm offset
i assume thats why they limit at 147, cuz then the tires become a liability. but i have z rated tires right now, and they feel absolutely stable at top speed... and in terms of 170... well i dunno... but i know i definitely couldve gone faster than what i was doing... the car was picking up speed pretty fast considering it was going over 120, where most other cars need miles for every extra 1mph.
'02 Nighthawk TL-S
__________________
'00 Nighthawk TL
'02 Nighthawk TL-S
__________________
'00 Nighthawk TL
I'll back that up .. his car did feel like it had more oomph to go .. dont forget he has Z rated tires, springs (which lower the car and theoretically should reduce wind drag), and headers which, at the top end, add some HP .. would be interested to find out its physical drag limit.. plus all sorts of thigns like weather and such play a role once you're going that fast
-Fiddler
ControlGenie Automation Systems
1998 Accord EX V6 Coupe (HomePage)
-Fiddler
cycdaniel
12-17-2019 11:58 AM
BoricuaTL
04-08-2016 02:08 PM
