Anyone have problems with their HEATSHEILD???
lately i have been hearing some grinding, took it into the shop and they said the welds on my heatsheild cracked. what the hell is up with this?
add this to the list of problems with my TL
1. header resonance
2. blown hid bulb
3. heatsheild grinds
4. paint chips
5. new tires
ARGH!
1. header resonance
2. blown hid bulb
4. paint chips
5. new tires
ARGH!
When I had my Megans installed the shop let the exhaust hang under its own weight causing my heat shield welds to crack. I thought it was resonance at first but it turns out the heat sheild was vibrating against the cat due to the cracked welds. That heat shield is very thin and the rust ultimately turns it brittle.
Did you just have your headers installed? It may have cracked then.
Really its no big deal though. Its like a $30 part for a brand new one.
And while they are under there, have them check the rubber bushing inside your exhaust hanger. That rubber splits when it dries out over time.
Once they fixed my heat sheild and exhaust hanger I had no more noises, or what I thought was resonance. Turns out I never had 'resonance'.
You can just rip the heat sheild off, but be careful if you ever park in grass, especially if its high. :angryfire
what does this header resonance sound like? and do you hear it at idle or only when accelerating???
my headers are on their way and i'm trying to figure out what to expect.
its the heatshield like i said before look into the RT or Magna Flow a direct replacement would be sweet if your thinking about a complete new exhaust system(intake,headers,cat,and exhaust)
good luck
Yes the megans have an extra flex pipe which in turn ends up sitting really close.......I know my flex pipe is already scraped off although the header was not compromised
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
