Anyone experienced engine Damage/premature wear from UR pulleys
2400 Watts in a TL...Why?
1 Post
I have been browzing the thread on this topic below and a question that hasn't been addressed yet was premature engine wear due to using UR pulleys ...
Has anyone here had solid evidence that the lighter pulleys will cause premature engine wear?
Understand that this car isn't designed to drivin' WOT all the time like some members drive. I drive casually with my Tl and enjoy the Hp and torque it has. I would obviously want more and I am leaning twords the UR pulleys because of the low end gains - most MODS will give high end HP which isn't as useful for casual driving - .
The main reason for these comments on the premature wear, was because the stock pulleys have a "Harmonic Ballancer" or something like that??
Someone made the comment that race cars that use these racing pulleys have the ability to rebuild the engines after each race, and we obviously don't.. Race cars are also driven for the majority of the time fractions from redline, hence "racecar".
So my question, as long as you don't always drive like a maniac, would the pulleys cause much engine damage?
and, How long has anyone here had pulleys installed on their car? any problems? any reccomendations regarding the "charger seriese" vs the "regular" UR pulleys?
Thanks for any replys ......
that old thig about them causing the engine to wear out came along time ago, from alot of cars havng to remove the harmonic balancer, that isnt a issue on the honda. i have a honda engine that has over 150,000 mile on it with a whole set of ur pullies on it and its still running (well it would be if i were to ever put it back into another car)
it wont make a divverence on how you drive either. if you like to hammer on it alot you will be fine. on the tl the only thing you are replacing is a pullie and not a balancer.
1 Post
it seemed like the ballancer was built into the pulley, I have no first hand knoledge with this, but it sounded that way when I read the other post.
can you confirm this statement? i'm with residualfreedom on this one, as i've heard that the harmonic balancer was designed as part of the stock crank pulley. if you can drop a link or show me something that proves the harmonic balancer is not part of the oem crank pulley, then i would feel "safe" about doing this UR crank pulley mod. let me know what you find out. thx!
My opinion about the whole problem with worrying about a mod damaging something on your car is..
DON'T DO IT IF YOU ARE PARANOID ABOUT AN AFTERMARKET PART DAMAGING YOUR CAR.
Originally Posted by patrick
fsttyms1:
i have to agree with Mongolian though.
1 Post
There is a big difference between Research and Paranioa, this is the first time I have asked questions about this and the search feature isn't working so I thought I would ask. that is usually the best way to research something you're going to be doing to your car...ask questions....but thanks anyway.
fsttyms1 : have you had the pulleys on a while, I would assume you have. It looks like you have been modding a while. I was just looking for someone that has had them installed a while for an opinion. I am leaning twords picking one up, I think I will pick up the charger series though..
Show me da MONEY
You might want to get some first hand info from chuckstl. I met him at one of our track meets here in MD. He has pulley's and plenty of other mods on his 2000 TL, and he has 175,500miles on it. I'm curious to know what his input would be. I am also thinking about purchasing the UR crank pulley, so any info is greatly appreciated. There are a few post on the CL site regarding these as well.
Just get 'em!
I think there is one story total of any problems with the pulleys and it was due to some rather unrelated issues.
The pulleys are pretty sweet. They almost give a bit of a supercharger whine when they wind up. The car responds noticeably quicker and at the top end the needle gets to redline a whole lot faster. If anything, I, and a number of members of ACL.com, have noticed that the car actually feels smoother after the install. You wouldn't believe the difference in weight and quality compared to the stock parts!
Do it! Order the gates belts once you get them and you'll be set!
I ordered the polished set and they look sweet. Also, just order the whole set so you can see them--the crank is almost not visible unless you really look for it.
You really feel them in the top end-as ususal for our cars--but the low end revs up faster as well. Money well spent.
In Pursuit of Perfection
If i purchased only the UR crank pulley will everything still work fine? purchasing the 3 peice set doesnt increase ne gains correct? Are the other 2 pulleys just for show and are just lighter? So the major part is the crank pulley which gives hp/tq?
BoricuaTL
04-08-2016 01:08 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
