Anybody with Koni's and OE springs?
Do the Koni adjustable shocks lower the spring perches giving the ability to lower a bit (I think up to 30mm) and/or equal out the wheel gap (for us conservative owners) and still use the OE springs but allow us to dial in a more agressive rebound rate? Anybody have experience with these Koni's or constructive opinions about using this set-up?
thanks
thanks
I am also looking for a response to this question. Just installed Comptech Sways and still looking for that tighter feel.
2000 Acura TL, White Diamond Pearl, Factory Wing, AEM Cold Air Intake with bypass valve, 225/55-16 Toyo Proxes FZ'4s, Comptech Sway Bars, Astro Start Remote Starter Model 1105
(Remote starts from 1,400')
Thanks for reply TL Daddy.
How does the adjustment work. Can I assume the fronts are adjustable from the engine bay but the rears have to be removed to re-adjust the ride? Also, do we reuse the existing spring perches or does Koni supply new?
thanks
thanks
Koni's come with one adjusting knob for each pair of shocks. Use this removeable knob to soften ~ stiffen the ride. Each shock comes with 2 machined grooves and one metal circlip. Move this circlip to the upper or lower groove (this is your spring perch seat) to adjust the height. The uppoer groove is to be used with lowering springs, the lower groove is used with OEM springs to lower 1 inch.
Koni does supply new spring perches - the only thing you'll have to reuse is the accordion-style dust boot that goes over the shock, but you'll have to file the hole at the top a little to accomodate the beefier shock piston rod.
....one more thing, yes the fronts can be adjusted (firmness) from the engine bay. You will have to remove your back seat each time to get to the top of the rear shocks unless you make some kind of access from the trunk or even better, the rear deck.
Thanks again TL Daddy,
I thought there would be a little more adjustablity in the height of the spring perches but I think it will be ok. Can always change springs later if needed. It seems like my OE springs have settled down 1/2" or so since new so this may be my solution to lower the front wheel gap to equal the rear and get a firmer ride. I'll order from Tim this weekend and take measurments after install if anybody else out there is interested.
Guest
Posts: n/a
If you use the koni's for instance to lower 1 inch, wouldn't that just kill your springs? The ride would be terrible compared to Comptech srings, correct?
'00 Acura 3.2TL Laguna Green
9005 Piaa Plasma's
Osram Diamen side markers
V1
other mod's coming after the winter...
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by ugen78 on February 05, 2001 @ ]</font>
9005 Piaa Plasma's
V1
The Koni specials are designed to work with both OE and aftermarket springs. You are just lowering the spring perch down 1" for the OE springs (as Koni designed for) - coilovers do the same thing but use a threaded body. Try their site www.koni-na.com
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
