Anybody blown a timing belt?
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I was just wondering if there's anyone here who has blown a timing belt. If so what was the mileage and age of the car. I'm at 80000 on a 00 TL and am considering changing before the factory reccomendation of 101000 miles.
185,500 on my original
happened on our mazda mpv at around 115,000km's luckily the car was going at a slow speed. ive heard of people on the highway blowing their timing belts and pistons shooting right through the heads
Dragging knees in
Originally Posted by whatwasthat
wow, i didn't realize the great effect of the timing belt..
what does it actually do?
Similar to a timing belt failure, my friend's cam gear slipped and sent the exhaust timing way too advanced while on the dyno.
This is what a timing failure (whether it's a belt or gear failure) can do to the engine -- my friend's heavily modded B18C5.. or what's left of it.
![](http://www.msu.edu/~mishraa1/block.jpg)
![](http://www.msu.edu/~mishraa1/head.jpg)
![](http://www.msu.edu/~mishraa1/valveschillin.jpg)
![](http://www.msu.edu/~mishraa1/fingering.jpg)
NOTE to Self: DO NOT put off getting the timing belt replaced and replace it before the manufacturer suggested time.
Pure, great pictures, really "drives" home the point of what the timing belt is all about and what not changing it will do to our cars.
Insepct it
Originally Posted by Liftedoff420
how do you check if your timing belt maybe needs to get replaced really soon
just remember guys this isnt a weak part and its not like as soon as you hit 100k the thing will break. ive seen new ones break and ive seen originals with over 400k on them. its a recomended replacement at the specified time but not life or death
Originally Posted by fsttyms1
you really cant. if your going to go thru the trouble of inspecting it, it might as well be replaced.
Ehh I say that the condition of the other visible belts are a good estimate on the wear of the timing belt. Both pieces are rubber and are used the same amount so if it looks like ur drive belts are wearing, usually your timing belt is too.
Money is funny.
Anyone get it done frm dealer or elsewhere?
How much does it cost to replce the belt at the dealer? And how much does it cost to get it done somewhere else? There's a a garage that won't charge for parts if you bring your own, but the timing belt is not too expensive anyway...like 25 bucks...so...opinions? Thanx!
By the way, JimmyTLS, I see you're from South philly. You don't happen to be one of the crew that hangs out by the Pho HA on 5th and Washington in the Asian shopping center are you? If so, maybe we'll have to have a little philly meet!
Originally Posted by patrick
True on both counts. The question we have to ask ourself is how lucky do we feel if we push it? Kris, 185,500 miles is really pushing it (IMHO). I guess you're feeling very lucky yes? ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
its kinda like that change your oil every 3000 mile crap. i dont buy into that either
not pushing it nor do i feel lucky. just past experiances tell me im safe
its kinda like that change your oil every 3000 mile crap. i dont buy into that either![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
i've had quotes of between 700 and 900 but that includes changing all the drive belts and the water pump. i don't see that many people who have blown thier belts here so maybe acura is right in thier recomendation to change at 102000. seems there's more blown transmissions than timing belts on this board.
Originally Posted by scottiew
So do you ever intend on replacing it or do you plan on just letting the motor blow?
Its not realy a matter of how many miles are on the belt as how many years. If the belt had 100k miles on it & only 1 year old doesnt mean you should replace it. Rubber gets hard & brittle by being in contact with UV rays and air/pollution more then by use.
Originally Posted by Pure Adrenaline
dirty.... i like it ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Originally Posted by 03CoupeV6
Why is that breaking a timing belt destroys the engine in some cars, but not in others?
If the timing belt breaks on a non-interference design, there is enough clearance between the pistons and valves to prevent damaging contact. An interference design does not have sufficient clearance between those parts and engine damage would result from a broken timing belt.
Dragging knees in
some are designed so that when teh belt breaks teh valvs arent left in a position to colide with the piston
The engine in the pictures I posted, the valves were broken and the sodium came out of the stems, melting the pistons.
Which leads me to a question for you, Kris. Are the valve stems in our cars sodium-filled, like the B18?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Dragging knees in
this isnt dealer necessary rigth? it seems these 700-900 dollar quotes are coming from a dealership...im sure a local shop would be much cheaper
Definitely. A timing belt change is a timing belt change. You could save some bucks by taking it to an independent shop. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
