any way to adjust HID?
Old Apr 6, 2001 | 10:51 AM
v_i_s_i_o_n's Avatar
Post any way to adjust HID?
i know this is a past topic, not a lot of responses..
anyone tried to adjust there HID or know how to?
00' Acura 3.2TL Nighthawk Black Pearl
- 18's Lowenharts LGM Chrome (3 piece)
- 225/40 NT555
- Factory Kit
- Factory Spoiler
- Apexi N1 WS coilovers
Old Apr 6, 2001 | 10:57 AM
Shoofin's Avatar
Post
Ther should be some knobs that can be adjusted by hand, or with a screwdriver directly behind the headlight unit under the hood. Check the owner's manual. It lets you raise or lower the beam, or direct it more left or right..
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Old Apr 6, 2001 | 05:47 PM
Post
If you can't figure it out, take it the dealer. They shouldn't charge for that kind of work...
Old Apr 6, 2001 | 08:27 PM
Jens
Guest
Posts: n/a
Post
There are two adjusment points on each headlight.You will need a long phillips head screwdriver and a small flatblade screwdriver.If you look at the rear of your headlight housing for a bit you will see two crown gears,these are your adjusters.The long screwdriver slides in thru the top rear of the headlite and engages the crown gear this will allow you to adjust both left and right and up and down.You may need to remove the black trim panel along the radiator support to get better access.Use caution when adjusting your light make incremental changes and drive the car and see if it is more to your liking.Always keep in mind that xenon lighting is very bright so do not adjust to the point of blinding oncoming traffic.I believe the adjustment procedure is also covered in your owners manual.Jens
Old Oct 2, 2005 | 09:45 PM
Petrie1997's Avatar
this thread was sooo helpful!!! just readjusted my headlights after clearing out the corners. covers the ground so much better =)
Old Oct 2, 2005 | 09:52 PM
bkzjimmy's Avatar
NiGhT rIdEr
dealer told me $45
Old Oct 2, 2005 | 09:54 PM
InspireUA5's Avatar
極品インスパイア32V
Originally Posted by bkzjimmy
dealer told me $45
$20 CAD at dealer....
but last time I brought my car to service and they adjusted for me w/o charge
Old Oct 2, 2005 | 10:24 PM
Got_3.2?'s Avatar
vision.. do u have ne pics of ur TL? ur TL sounds nice on ur sig.
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
