Any reason one-touch down wouldn't work?
Old Feb 21, 2005 | 01:57 PM
Whizzbomb's Avatar
WhizzBomb
Hey all,
For some reason the drivers side window won't go down using the "one-touch" anymore. Could I have accidentially done anything to disable it? (Like not having the L/R side mirror switch not in ths middle disables the passenger mirror point down when in reverse?)
Thanks,
Joe
Old Feb 21, 2005 | 02:11 PM
bkzjimmy's Avatar
NiGhT rIdEr
i say ur best bet is to bring it to the dealer
Old Feb 21, 2005 | 07:34 PM
pistacio's Avatar
Drivin' it till it dies!!
Look in the owner's manual. There's a procedure in there to reset it. Usually it's if you disconnect the battery the one touch don't work. I think you have to hold the switch down until the window is completely down, and continue holding it for a couple of seconds, then do the same closing the window and holding the switch a couple of seconds after it's closed.
Someone correct me if I'm wrong.
Old Feb 21, 2005 | 08:09 PM
Bxscig's Avatar
Yeah, you must of disconnected your battery for a bit. You can just bring it all the way down and hold it for like 3 sconds and then bring it all the way back up and hold it for 3 seconds. It should work now.
Old Feb 21, 2005 | 08:31 PM
set your seat. press the memory button to save your position again and it should work.
Old Feb 21, 2005 | 09:16 PM
Whizzbomb's Avatar
WhizzBomb
Ahhh. I did disco the battery recently to work on the HIDs. Thanks for the info
Joe
Old Feb 22, 2005 | 08:07 AM
Whizzbomb's Avatar
WhizzBomb
Thanks Bxscig. That totally fixed the problem
Joe
Old Feb 22, 2005 | 08:17 AM
Bxscig's Avatar
No problem, I had the same problem years back.
Old Feb 22, 2005 | 08:39 AM
Type S Lady's Avatar
Originally Posted by Whizzbomb
Hey all,
Thanks,
Joe
Mine went out atleast every two months, they said the would just reset and it only took a minute. Happened about 10 times.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
acurajj
Sep 19, 2015 03:47 PM
dlknight
Sep 3, 2015 07:54 PM
