Any downside to painting engine cover?
Okay, about to go into the body shop in an few hours... Am having some hesitation on getting the engine cover painted...
Any downside to doing this? Will I be dealing with damaged paint over the years due to the amount of heat? Cracked paint, etc...needing rejuvenation...
Or will it have the durability of basically any painted item on my car (like the painted mirrors, etc)... Will I basically be able to also treat it as any painted item on my car (wash, wax, etc...)...
Thanks all!
Thanks all!
if its a body shop thats painting it there is NO down side to painting it, other than if you want it back to stock you will have to buy a new one. mines been painted for along time now (probably 50k miles) and its still in as good as shape as when i sprayed it. many others have done it and have no issues and wont.
just do it
just do it
Still sluggin' it out
As long as you prep it correctly, you will not have any trouble. I washed mine with dawn, let it air dry, and applied 3-5 light coats of spray paint. No sanding at all and I've never had any trouble with it. No cracking or peeling...
Originally Posted by fsttyms1
thats not preping it properly. you should have used atleast a scuffpad and scuffed teh surface, then applied prmer
I guess I lucked out then, huh?
Originally Posted by bkzjimmy
yea, u wont be able to drive with ur hood open for everyone to see it
i never thought of that!
and if you want a really trick job he could superglue some plexi glass to cover the hole and stick neons under the hood to light up the engine cover!
ഥഎണഡഏ Fellas Inc.
Originally Posted by MikeekiM
Hmmm...just got back... They are not going to do it as complimentary work...
They want $150.00... Not sure I want to do it that bad...
DIY...
1) take it off engine
2) remove the LETTERING piece (or tape lettering to spray around letters)
3) dawn/orange glo and warm water to get it clean -> air dry
4) use sand paper to scratch up the surface
5) blow off any particles OR (what i did) wash it again and let it air dry
6) thin coat of primer -> air dry
7) thin coat of color -> air dry
8) repeat step 7 until everything is the way you like it
9) clear thin coat -> air dry
10) repeat 9 if you want
All in all, it took me about 4-5 hours on a blazing hot day. I air dryed everything on my deck in the sun. No probs since 06-07-2004. I'll try to find pics (they are somewhere among 650GBs)
BTW you could wet sand after color but I didnt find it necessary and I was satisfied with my results (GDS looking for pic)
Good luck!
Thanks! Pics would be great...
To be honest, this was a project of opportunity... I have the car in the shop anyway... They've mixed the paint anyway... why not do it...
Now that it's been promoted to a DIY... I will need to find some spare passion to get this done separately...
here is mine and another members
Originally Posted by njzprettyboy
ive read that once, the paint dried up on the engine cover, and evaporated through the plastic and killed the engine. good luck!
Ganji, Want some?
hey just wanted to show off my paint i just did it not too long ago i photochopped my pic and forgot to save a copy of the original but you see it OH and my car is green so i figure it would look good with this on here..
only downfall is that no one will see it but anyone you STOP n show it off too, not like too many will be jumpin up and down to see it but, yeah i think its a start to other mods!!! good luck!!!!!!!!
Ganji, Want some?
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
