ANY 2Gen TL w/ ......
Well i'm looking into new molded on my TL an trying to find out...
Is any 2gen TL out there that has LED turn signal mirror an I'm not talking about added LED strip with 3m taped. I'm talking about the ones found on TSX. Try to get some idea on how do this molded.
I think i found a easy way to do this an that is to buy Mirror cover w/ LED turn signal found on BMW 91-99, Scion Xb, an Nissan Maxima 95-03 an just rebonded sanded an painted it. Also here some pix of mirror cover w/ LED turn signal.
ANY Other GOOD IDEA AZ guys ?
sup guys, MK, it wasnt too bad as the car was in the shop getting other work done. I had two sets made, one which Streeteffects made which the molded the TSX blinker into the stock TL mirror housing, and these which just molded the entire TSX mirro onto the TL base. I liked this set better, so I sold the other to a friend. These are molded on and do not break away. The other set still retained every single stock function, IE heat, power, breakaway etc. These are still powered, but not heated. The 1st set took a little longer to be completed. These if I recall correctly took about 3-5 days.
I'm stock and hating it.
Originally Posted by lokee99
Who did your second set?
If you don't mind me asking.
Originally Posted by AznWayTL's
Hey njzprettyboy, how much did it cost you to get this molded done
If you are very interested I could see if my friend would sell his set, but he is going to want at least $350. PM me if you like...
boku
01-30-2008 11:45 AM
TL-A-Spec
04-25-2007 08:57 AM
