Another tranny question
Old May 21, 2012 | 08:43 AM
CAB NY's Avatar
Tri State ViP Crew
i know there is a problem but trying to get a idea if its something serious or could it be minor it just started doing this at slow speed or at a light hit the gas nothing for about 3 or 4 seconds but at high speed no signs of problems changes gear as normal this happened about 5 times
Old May 21, 2012 | 10:15 AM
Vman159's Avatar
I don't want to scare you but that's how mine started. Check fluid Level and smell . Any lights ?
Old May 21, 2012 | 03:34 PM
CAB NY's Avatar
Tri State ViP Crew
had it checked but all was good right now no lights or codes they said to keep driven until it gets worse then bring it back
did yours just die on you or did it take time i don't want to get stuck but right now its still running good
Old May 21, 2012 | 11:04 PM
Vman159's Avatar
Well the same thing wa happening to me except I had shudders sometimes . I brought it to the dealer and they recommended and said a transmition flush would fix this problem . Turns out 500-800 miles it locked up on me on the freeway and all my gears died besides 2nd .
Old May 23, 2012 | 09:20 AM
CAB NY's Avatar
Tri State ViP Crew
Its doing it more now at stop slow speed hit gas nothing but if i put in N and back to D5 its good
Old May 23, 2012 | 06:34 PM
CAB NY's Avatar
Tri State ViP Crew
had it checked and forgot the exact part name but think he said the first gear bearing or sprocket that engages when going to 1 to 2 if anybody knows the part labor 695$ part 170-290$
Old May 24, 2012 | 10:13 AM
01tl4tl's Avatar
$2500 part number #%rebuild trans
each gear has its own set of clutch packs. 2nd and 3rd are the worst for us
they also share gear shafts--example 2 and 5 so when part goes so will the other gear
the clutches keep the trans engaged--when they wear out- you get delay as it searches for grip
Its worth draining a 4 oz atf sample and send to blackstone labs for 25 bucks, to know whats happening inside for sure--bad particles or just crud
there is a chance you can run some new fluid, and clean the selenoids/pressure-shift things
If they are clogged it may help engage better
BUT
DO NOT go to the dealer or a trans place= and get a full power flush!!
too much new fluid -under pressure- with its cleaners, can dislodge remaining crud thats keeping any grip at all!
Im sure the trans shop said keep driving it~
see threads on accord trans swap for a 1500$ option to rebuilding yours
Old May 24, 2012 | 10:18 AM
01tl4tl's Avatar
when cold: does waiting 2 minutes in P before shifting to R or D, make it better?
If going to N and back to D helps it--you may be able to save whats left with some new fluid and maitenance- no guarantee of course!
I would do the `blackstone labs` test asap and proceed based on their reading
http://www.blackstone-labs.com/
No point dumping 50 bucks of fluid into something thats got way too much clutch particulate matter in the fluid (example) = known trans death around the corner,,,
Old May 24, 2012 | 10:26 AM
01tl4tl's Avatar
did you ck fluid level per book- 15 minute freeway cruise from dead cold- no city stop and go -
level needs to read BETWEEN the dots. not at either at that temp--between
how long between changes of atf for you? ever?
Old May 24, 2012 | 07:15 PM
CAB NY's Avatar
Tri State ViP Crew
had enough dropped it off today I'll see what they tell me in a day or two
Old May 25, 2012 | 08:05 PM
CAB NY's Avatar
Tri State ViP Crew
took it to AAMCO because after they check the car by driving it they basically had an idea of the problem should be about 1000$ i assume a little more but now its apart they showed me all these parts that supposed to be bad i don't really know but now they want 3200$ and that's with city employee discount that's B.S. if i knew that the car would have sat for a while i'm still driving so i said forget it and now have to pay 700$ to get it back that's their labor i priced other places for a lot less for a rebuilt tranny
TypeS860
Jan 10, 2026 11:11 AM
Pham Alvan
May 18, 2021 06:48 AM
Pham Alvan
Mar 16, 2016 09:17 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
