Amber bulb help
distinctiv_tuning
Amber bulb help
hey guys wasup...i need to get a Amber bulb that will fit a 99-01 rear turn signal size?...u guys know where i can find it?..or a part number?...thanks
Need a WHAmbulance
Here ya go.
Bulb types listing for 99-03 TL (Know that for a certain bulbs there can be many different names or types depending on which has higher watts, I tired to list all the possible bulbs that will fit a certain socket)
Interior
*Note* 194 and 168 are the same bulb with different wattage, 168 is the brighter bulbs. All interior bulbs are 194 (except the trunk) but can be replaced with 168 or vise versa. Reverse/Backup light is 921(T16) by stock but can be replaced with 912(T15) and also 168/194 but brightness may be dimmish.
Door courtesy lights= 194/168 (qty 2 for both doors)
Map light = 194/168 (qty 2)
Glove compartment = 194/168 (qty 1)
Center console = 194/168 (qty 1)
Dome = DE3175/3175/T6 (qty 1)
Trunk light = 168/194 (qty 1)
Exterior
Headlights = D2R (HID), D2S bulbs can be fitted with slight modification (qty 2)
Front Turn sig = 1157 (qty 2)
Highbeam = 9005 (qty 2)
Backup light = 921(T16) default/ also known as 912(T15) / W2 (qty 2)
Brake light = 7443 (qty 4)
Upper Brake Light = 7440 (qty 2)
License plate light = 168/194 (qty 1)
Rear turn sig = 7440 (qty 2) *NOTE* 99-01 TL only
02-03 TL exclusive
Rear turn sig = 1156 (qty 2)
Front parking lights = 168/194 (qty 2)
Fog/Driving lights = 9006 (qty 2)
Interior
Exterior
02-03 TL exclusive
distinctiv_tuning
nooo u guys didnt get the question...Here lemme give some more info.....i have a 02-03 rear tl lights...u now the clear ones....and i have that installed..but....the turn signal bulb that is in the car...is that white color...it is white because the old tail lights had that yellow shyt inside....now i need to get a bulb that is yellow...or amber ...that will fit in the socket of the 99-01 turn signal.
distinctiv_tuning
yea...i thought i didnt need it...now i just need the turn signal part...for both sides...thats all..u guys noe any site or anything from where i can get them from?..thanks for the help
What your problem is?
I don't want to hijack the thread, but where do you find the clear or white bulbs for the rear turn signals? I have been looking to take out my amber ones and put in some white ones. What is the replacement bulb if they make a white one that fits????
BlingBling INSPIRE 32V
Amber bulb for rear turn signal?? :sqnteek:
Watch out for COPS!!
Amber or red are the only street legal colors for the rear turn signal. I have the platinum coated ones for my '99. I have the DEPO aftermarket tails.
Try this: http://www.cardomain.com/item/APC504144B
Or this: http://www.autospeedy.com/lightbulbs...asp?ID=RAYR183
TL = Tranny Lubrication
indMFP: I don't want to hijack the thread, but where do you find the clear or white bulbs for the rear turn signals? I have been looking to take out my amber ones and put in some white ones. What is the replacement bulb if they make a white one that fits????
Here is the link for what you want:
http://www.jcwhitney.com/autoparts/P...p-4766/c-10101
White Neon-coated Type 7440 LED Performance M3 Bulb Each ZX472774T $9.95 not including shipping.
As for the original question: hey guys wasup...i need to get an Amber bulb that will fit a 99-01 rear turn signal size? u guys know where i can find it?..or a part number?...thanks
You will need to look for a Rear turn sig = 7440 (qty 2) that is in amber or red, if indeed that is what is needed for a 2000 Acura (remember if you don't change your harness you will need to look for these lights.)
When replacing your 99-01 you don't necessarily need a harness you can clip on the same one, the only issue is with the turn signal. 1) It is not the same size and 2) It is the wrong color (white), it needs to be amber or red to meet our "street driving laws". Many have changed it to white and have not been busted, but you can be....
Additionally you could always Spray on bulb Paint an Orange color!
http://www.autospeedy.com/tinting_fi...ect=Bulb+Paint
Phil 4:13
If anyone is interested...
I have amber leds in my tails and front turn signals. I love the on - off effect leds give, however they do give you the "hyperblinking" effect which I happen to like. This can be fixed by buying a load resistor kit. Led's and the resistor kit can be purchased at www.superbright leds.com. Sorry I don't have any pics - I am too broke to be that technilogically advanced ight now
ripit
09-26-2015 06:19 PM
