!! ALTERNATOR ( maybe ) HELP ???!!!
~~~ SKY'S THE LIMIT ~~~
99 TL--178K miles
so this morning i went to work and stopped at the gas station--shut my car off and went in---came out started my car and there was this weird ass humming noise--even when i turned the wheel it sounded different
the mechanic said it was the alternator----how can it be possible that it just went out in the matter of seconds ???
also i can smell sumthin funkey coming from the alternator and if i put my fingers on it i can feel it vibrating
how hard is this to change out----and he said i should get the tensioner pully while in in there too
ADVICE ON THIS SITUATION ???
thanks in advance
thanks in advance
sounds like the shaft bearing went out
a mechanics stethascope will tell instantly
remove alt-
take to parts store for verification- if needed,,if it turns slow- drags- etc--its bad
I find it wise to replace belt tensioner with a belt or bad part,,lets say the alt was locking up and moving again - thats going to damage the belt and freak the tensioner out
remove alt-
is it safe to drive when its makin that noise and when it smells like that ----just kinda nervous to drive it
in fact since it happend i havent driven it at all----i left it at the shop i work at
the mechanic said if its bad that im running off the battery---cuz the alternator isnt charging it ( if its bad ) and i have a yellow top optima
safe to drive it about 15 miles or no ????
Jul 16, 2017 07:33 AM
