Alarm not working
Old Oct 22, 2005 | 01:33 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
Alarm not working
So i just finished washing/claying/waxing my car, and as I walk back in the house I try to arm the alarm, and to my surprise, the car doesnt "honk". So i check if all the doors are closed, they are. Trunk, shut... Hood? shut, too. So i try again, nothing. And the security light doesnt light up, and i tried unlocking a door from the inside and opening it, no sound... so the alarm is really not arming... WTF? it worked fine last night.
Old Oct 22, 2005 | 04:24 PM
khoifl's Avatar
unplug battery cable. reset the car.
Old Oct 22, 2005 | 04:37 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
First off is this an aftermarket alarm or the factory keyless entry? IF its an aftermarket alarm you might have it in Valet Mode.
Old Oct 22, 2005 | 05:10 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
stock alarm...
Old Oct 22, 2005 | 05:21 PM
AcuraTL's Avatar
OG
Do you see the blinking red light on when you push arm on your remote? If not, then change the battery to the remote.
Old Oct 22, 2005 | 05:44 PM
bkzjimmy's Avatar
NiGhT rIdEr
even tho the doors are closed, check to see if the locks are goin up and down.
this happened to me once
Old Oct 22, 2005 | 05:49 PM
pimpravi's Avatar
I pimp an Audi A4.
yeah it happened with my stock alarm and still happens with my aftermarket.. weird but it still locks
Old Oct 22, 2005 | 07:21 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
well the problem is gone...alarm works now
and yes the locks were going up and down, and the remote is working.
Old Oct 22, 2005 | 09:15 PM
You tripped it into Valet Mode. You can do that with all alarms, even aftermarket ones. To activate it or deactivate, you open the front passenger door, hit:
1. Lock
2. Unlock
3. Lock
When you hit lock for the 3rd time you will hear the sound of the locks being closed but it won't close the locks will still remain unlocked. The car is now in valet mode. To undo it, you follow the same procedure in that exact same order.
Old Oct 22, 2005 | 10:13 PM
Bxscig's Avatar
He had a stock alarm though, I dont beleive there is a valet mode... is there?
Old Oct 22, 2005 | 11:59 PM
I thought there was... but now you got me second guessing.
Old Oct 27, 2005 | 12:18 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
well it seems like my alarm system is no longer working
the horn honks when i press the lock button 2 times, but the security light doesnt light up, and i can open the doors/unlock them by hand, and the alarm doesnt sound.... fucking POS
Old Oct 27, 2005 | 01:06 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
First off, are you waiting 30 seconds after the "honk". Wait 30 seconds, then open a door by hand - the alarm will sound. If you do it before 30 seconds, it will cancel the arming process.
Second you can have a bad hood switch that you won't be able to find by looking, and it will cause the alarm not to function. It will lock and unlock the doors, but there will be no "honk".
Old Oct 27, 2005 | 04:48 AM
chewi's Avatar
I had a similar problem before,
The problem was my Trunk Latch was sticking sometimes which prevented me from arming the car and sometimes I would get false alarms.
I the REd LED wouldn't blink either. But it did lock the doors.
Best bet is to get it checked out by your dealer
Old Oct 27, 2005 | 07:19 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
we might have a winner
i'll try waiting for longer before doing anything... i'll keep you updated.
Old Oct 27, 2005 | 02:42 PM
03CoupeV6's Avatar
Yes let us know. If the car honks, the alarm is arming. The lack of a blinking Security Light might just be a blown LED. I had this happen to my last Accord.
Old May 17, 2015 | 09:54 AM
2beertom's Avatar
I had this same problem. It turned out the alarm was not activating because the hatchback was not locking. I bought a new actuator from rockauto.com for half the price of the dealer. The part swap took about twenty minutes. The actuator is the white plastic motor that works the lock.
Old Oct 9, 2016 | 06:16 AM
2008.Tl's Avatar
Alarm Not Working
Hi , I seem to have a similar issue with the alarm as well. The problem with my 08 is that when I press unlock the lights on the exterior flash and work, however when I press lock again you can hear the locks click but I get no beep and no lights on the outside. Also, my driver side security light does not flash indicating that the alarm isn't armed. Does anyone know what the problem might be ? No horns or beeps while locking or unlocking the car and lights only flash when unlocking.
Old Oct 9, 2016 | 06:43 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
You have posted in the wrong section - should be in the 3G section.
The fact it is not arming means the circuit is open. There are eight triggers/switches that need to be checked as follows
4x doors
Engine hood
Trunk
Radio
Ignition
Most common is one of the doorr switches. Make sure all are closed tightly as a start, but this may not reveal if one of the switches has gone bad.
Old Oct 9, 2016 | 10:58 AM
2008.Tl's Avatar
4x doors
Engine hood
Trunk
Radio
Ignition
oh my bad I wasn't paying attention. Il repost in a third gen forum. So maybe the hood latch on my 08 is messed up because it did have a minor accident with the last owner where she drove into a trailer hitch. thanks this really appreciate it.
mada51589
Jan 9, 2025 04:40 PM
spidermankb
Mar 5, 2019 11:34 AM
acurajj
Sep 19, 2015 03:47 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
ahsm
Sep 9, 2015 08:35 AM
