AEM pulley major problem
The belts for the AEM pullies are squeaking like hell now. I've used two full bottles of belt lubricant on them and they still squeak. I bet I have to replace the belts now. Does anyone know where I can get the belts for the pullies and if they are the same belt (the AEM pulley belt and the OEM acura belt)?
belt tensioner check?
if that doesn't work, go to pep boys and buy belts that are one size lower than stock. have them pull up on the computer the stock size, and then go the next lower size. worked for me! good luck.
these are over drive pullies they belt would have to be LONGER...anways dont follow that advice, just copy down the number on the belt its format is by length and width and part number....just copy all info on belt and bring in that info..
you're right!
OK, so i've determined that it's the belt on the AEM pulley towards the bottom of the car that is making the noises. (the smaller but wider pulley). so this belt should be one size lower than OEM, right?
the product is called aem underdrive pullies...if you gonna under drive a gear...the point is to make the parasitic pullies bigger so their easier to turn...while bigger pullies have longer diameters they also have more circumfrence....which would yield a longer belt needed to wrap around the pullies...why does this not make sense? squealing is caused by 2 things belt too loose or the belt over tighten...adjust it so its inbetween you should be fine...
BoricuaTL
04-08-2016 01:08 PM
InFaMouSLink
10-27-2015 06:51 PM
Abe_Froman
09-16-2015 01:27 PM
