Advice on Intake, TB, and Pulley kit.
I have a 2000 TL that i am going to finally begin working on.
I wanted to ask whether i should put on a TL-S TB with a short ram intake, i hear the sound is really good with the ram. If i do this, will the TB fit on the current manifold i have? would it be worth it to get type S manifold too or should i just get mine ported? oh yeah, also, if i do get the TL-S TB, is it a good idea to port the TB?
I currently have 2-12w3v2 JL subs running off 500.2 phoenix gold, which i think is about 600 RMS. Which UR pulley kit should i go with, the one with smaller crank, larger alt and PS or smaller crank, same size alt and PS, or same size everything?
With this work, how much wheel HP can i expect?
I have searched the threads but exact specifics weren;t found and people keep swaying off topic.
Thanking everyone in anticipation.
Received 1,080 Likes
UR crank pulley produces power
If you go with the TypeS TB, you'll have to come up with a custom CAI. The TypeS has a VSA unit which goes in front of the TB so if you go with a TypeS CAI it will be way too short.
Boomer SOONER
if you only have 600 watts RMS then you should be fine with the underdrive crank pulley - you will be boarderline though. I would get the Optima yellow top battery and/or a 1 farad capacitor. With those you will be fine with your current setup and the underdrive pulley.
I wouldnt waste your money on getting the type S TB honestly. Put that money toward some Stone racing headers (ebay for like $300). The headers will give you WAY more power than the Type S TB would.
So what i understand is forget about pulleys, even crank? What about replacing all 3 pulleys with the original sizes, is it worth it? Also, you say go with a cap and capacitor instead, forget the S-TB, what about short ram intake?
Thanx
Thanx
Boomer SOONER
Thanx
Thanx
I would get headers over the pulley or intake anytime. They give much more power.
hey I was thinking of doing the S-TB also but I never thought about just doing what patrick said and bore it out. Would it cost less than buying a junked TB??
If a go to a local machine shop, what do i tell them to dore it out to? isn't it at 2.5" right now? Is the S-TB 3"? Hey Patrick, i'm seriously concidering your so if you can tell us what you bored yours out to, that would be great. So do you regret going with the short ram, would you go with a full CAI now that youve seen the RAM in action?
I don't know what my speed shop bored my TB out to, because I forgot to ask. If your local speed shop has machining tools, they can do this very easily (assuming they do this kind of stuff). Or alternatively, you could get King Motorsports to bore out your TB - same idea, see link below:
http://www.kingmotorsports.com/produ...173&vehicle=TL
I found some nice OBX headers, one set is Ceramic the other Stainless steel. If i go with a Short RAM intake, do i want the Ceramic over the Stainless? why is the stainless 75 dollars more? whats the difference, theyre all the same size, right?
Also, anyone heard of the new GTX startup synthetic? 90% of engine wear is done on startup, so they definately have my attention, i'm trying to find out what i can about this.
Boomer SOONER
Also any synthetic will be much better at protecting during startup vs. dyno oil. Most of us use Mobil 1 - you can get the 5 quart jug at WalMart for around $22.
Originally Posted by ou sig
dont get OBX headers...and REALLY DONT GET OBX CERAMIC HEADERS!!! they suck ass and the ceramic coating will flake off and they will rust; get Stone racing headers, Alphawerks, Megan or Comptech (if you have some serious money).
MrHeeltoe
20
02-23-2023 01:54 PM
soupi
14
11-15-2015 11:15 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
