Adjusting engine valves
Old Mar 21, 2007 | 01:04 PM
tnewyes's Avatar
Can someone tell me if this is true?
My valves need to be adjusted on my 1999 3.2 tl; the rattling is really loud. The dealer quoted me $310.00.
He said since it is a 99 that the head gaskets would have to be pull and replaced.
I ask why and he said that they would leak oil if not replaced.
Also, would a bad PCV be another reason for the rattle?
Does anyone know how much a service manual for the 99 3.2 tl cost and where
I could get one?
Old Mar 21, 2007 | 01:42 PM
01tl4tl's Avatar
If you are good with basic tools you can do it yourself
Its time consuming to get at the valves
A private shop will do it for less than the dealer
Look in your local phone book
Old Mar 21, 2007 | 01:53 PM
MurkyRiversTL's Avatar
COTM Coordinator
Is there a DIY for adjusting vlaves, or is it something thatcan easily be fucked up.
Old Mar 21, 2007 | 01:58 PM
dwest1023's Avatar
I could get one?
If they are going to replace a head gasket and adjust valves for $310, I would say that is a bargin! Are you sure he did not mean Valve cover gasket?
Old Mar 21, 2007 | 02:04 PM
COTM Coordinator
I thought he was talking baout valve cover gaskets. If he is talking about head gasket, then hell yeah that's a deal. One guy wanted 700 for my 91 integra head gasket.
Old Mar 21, 2007 | 02:20 PM
fsttyms1's Avatar
They dont need to replace the Head Gaskets. They should however replace the valve cover gaskets.
PCV valve wouldn't cause the rattle.
You can get a factory service manual from Helms inc.
Are you sure its the valves and not the Purge Control Solenoid?
Old Mar 21, 2007 | 02:41 PM
tnewyes's Avatar
Maybe that's what he said (valve cover gaskets). I kinda shut down when he said $310.00
because I thought adjusting the valves was something simple. You always see that as part
of the schedule maintence. You know how it reads "inspect brake pads inspect whatever else you can think of and adjust whatever").
I'm pretty handy with tools but I'll take your advice and look in the phone book for a private shop.
Thanks everybody
Old Mar 21, 2007 | 02:49 PM
tnewyes's Avatar
I figure it was the valves because of some of the symptoms;
1. When the car is cold I don't hear the rattle it happens when the engine gets warm.
2. I hear it going up hills at a slow speed.
3. I hear it when I accelerate.
4. I hear it at low RPM.
Old Mar 21, 2007 | 04:21 PM
fsttyms1's Avatar
Thanks everybody
310 isnt bad. Its not something you "just inspect" the upper intake manifold has to come off, then the coil packs have to all be removed, then the valve covers.
Old Mar 21, 2007 | 04:26 PM
01tl4tl's Avatar
Some things I am happy to pay someone else to fix
This is one of them!
Run some Seafoam before and afterwards to clean the valve sealing edges and
make the whole system run better.
Throw in some NGK Iridium or Platinum spark plugs while they are in there for you.
Makes car like new
Old Mar 21, 2007 | 04:40 PM
fsttyms1's Avatar
(especially in the crankcase)
Old Mar 21, 2007 | 04:45 PM
COTM Coordinator
^ Do you just pour it in where you would put your oil?
Old Mar 21, 2007 | 04:47 PM
Eisenhulk's Avatar
MUCH bigger than you!!
This sounds like the EXACT SAME thing I'm experiencing right now.
Old Mar 21, 2007 | 05:39 PM
01tl4tl's Avatar
Regarding seafoam
In this case, pour the whole pint can into the engine thru the oil cap
Run it for 15 to 30 minutes before dropping car off for service
That will dissolve lots of sludge buildup in the oil passages- and those operate the valves,
so having them clean before adjustment is good. Have the shop change the oil while its there so you leave with fresh everything. Tell them you ran cleaner thru it and change oil before they drive after valve adjustment. Otherwise they see that really bad looking oil and get concerned
You would pay 100$ for this same intake cleaning service
Use a 2nd can right now- the vac tube method with 15 minute soak before restart and part of can in gas tank for internal cleaning of fuel injector sprayers
see thread Seafoamed the ol TL for 10 pages of directions
Seafoam 8 bucks per can
Old Mar 21, 2007 | 08:12 PM
fsttyms1's Avatar
Yes.
Old Mar 28, 2007 | 12:07 PM
Eisenhulk's Avatar
Sorry about the bump, but I'm curious if you have found out anything else about this problem.
Old Jul 30, 2007 | 12:31 PM
tnewyes's Avatar
Yes, it was the valves. I just got them adjusted and my car is riding so smooth. I love it.
The dealership charged me $225.00 for the adjustment.
Old Jul 30, 2007 | 08:52 PM
mcflyguy24's Avatar
Awesome. Always glad to hear about good dealership experiences like this one. Did you seafoam?
Old Jul 30, 2007 | 09:02 PM
JDM96specCTR's Avatar
that sounds more like detonation AKA pinging. what grade of gas are u running? if its not 93, then thats probly ur problem.
edit: just read further and saw that u got the valves done and it seems better...
Old Aug 16, 2007 | 12:38 PM
tnewyes's Avatar
Yes and I could tell the difference.
Old Aug 16, 2007 | 01:39 PM
mrempp's Avatar
I'm just gonna ask a question here rather than starting a new thread. My 03 TL-S has about 63,000 miles on it, could the valves need adjusted this early? When i drive down the ally at work, and when i drive by parked cars the engine sounds like its clicking really fast( for lack of a better word). Its even worse when the engine is cold. Its not the purge control solenoid, i had that replaced under warranty, and its pretty quite now. I wouldn't mind spending a couple hundred to get them adjusted if that is the problem. Any thoughts?
rockyboy
Aug 4, 2024 10:35 AM
IlliniAcura
Sep 19, 2015 09:31 PM
Sep 17, 2015 09:01 PM
Sep 14, 2015 10:48 AM
Tsov Tom
Sep 6, 2015 07:56 AM
