Acura Oem Radio stopped working. Wont power on but getting power.....
Has anyone had there radio just go dead out of the blue? Got into the car a few days back and radio wouldnt power on. Has power going to it as when you have the lights on it lights up. When the radio is unplugged and plugged back in you can hear it going through the cd slots but nothing more. Tape wont eject from radio either. Checked both ACC drivers and Radio passenger side and both are fine. Ive never had a radio just die on me like this and saw a few threads but with no resolution?!?!
Any suggestions would be great!
Mr.Helpful Diagram
Check for power and ground at the radio connector, there's one is constant power the other ACC power and of course a ground. If they check out ok then its the radio.
Jp32819 if you can show the radio connector diagram for the op, I don't have the service manual with me. Thanks
Mr.Helpful Diagram
The lights are powered thru a different circuit, That's why its lighting up
Mr.Helpful Diagram
Ill pull up the diagram and post it as soon as I get home today.
Mr.Helpful Diagram
![](https://cimg5.ibsrv.net/gimg/acurazine.com-vbulletin/649x777/screen_shot_2016_08_16_at_9_47_04_pm_7f94e8d061a1787a6b9ea71b0eee63fbada6efdf.png)
You should check A1, A2 for power then A20 for ground. If they check out ok then its your radio 100%
Ok after reviewing the diagram this appears to be the power supplied from the radio to other things so if thats the case it would make sense. A10 is constant and getting power to that at all times. A9 kicks on when light is enabled and A20 ground appears to be good as well.
Mr.Helpful Diagram
I messed up on A1 forgot to add the zero, Meant to say A10. It's definitely the radio, If you're going to purchase the same one make sure to ask for the code. You can interchange to 6cd player or single just make sure its not from a CL.
fury
06-27-2016 06:48 PM
BoricuaTL
04-08-2016 01:08 PM
