ABS Speed Sensor
Old Nov 8, 2017 | 08:23 AM
Christopher Nieves's Avatar
4th Gear
ABS Speed Sensor
Hi Guys
I recently took my 2002 TL to a local mechanic to replace the rear break pads and the front lower control arm on the front right side. When I picked the car up I noticed the ABS, VSA and /!\ lights on. I figured maybe it needed some kind on reset or maybe after a few starts the ABS system would reset but after a couple of days with the lights on and some research I went on and checked all the speed sensors only to realize the front sensor was missing the bolt. I need to know what size is the bolt that holds that sensor so I can fiz the problem? Any help would be appreciated thanks in advance.
Old Nov 8, 2017 | 08:31 AM
Should be this one: https://www.oemacuraparts.com/oem-pa...dXRvbWF0aWM%3D
https://www.oemacuraparts.com/auto-p...t/knuckle-scat
Old Nov 8, 2017 | 03:18 PM
Iggy's Avatar
make sure to clean the metal surface that the sensor rests on. without that bolt, all sorts of crud and rust accumulate between the two. If the sensor is not close enough to the field ring it won't sense a speed and trip the ABS light.
Old Nov 8, 2017 | 04:02 PM
4th Gear
Perfect thank you I just ordered it hopefully im getting the lights because the bolt is missing and the sensor is not getting a read cause it was working perfect before this happened
Old Nov 8, 2017 | 04:03 PM
4th Gear
Thanks I will make sure its clean this happened 3 days ago so hopefully it wont build up any rust and im just getting the light because of that bolt missing. I ordered it today once I install it I will update if the problem is solved
Old Nov 9, 2017 | 02:13 PM
Skirmich's Avatar
Why you didn´t go back to the mechanic and retrieve your bolt?
Old Nov 9, 2017 | 02:14 PM
that sounds too logical
Old Nov 9, 2017 | 02:40 PM
Skirmich's Avatar
^ I once forgot my wheel lug lock tool... Took me 1 week to realize, went back to the tire shop for it..
Old Nov 9, 2017 | 06:10 PM
4th Gear
Well I worked the next few days after i got my car back and it took me a few days to realize what was going on too Its a $1 or so bolt so I installed it myself and problem solved. Thanks for the help tho
