About To Paint "Y" Pipe...
I've bought high heat bbq spray pain thats ok for 650Celcius or 1200 F...
before i carry on, can u guys who've done this give me some advice and warnings???...
ur help is greatly appreciated... thanx alots...
I used Rust-O-Leum flat black BBQ paint, 1200 degree. Sound like what you bought.
Sand the pipe with 150 grit sandpaper.
Use denatured alcohol or grease/wax remover to take off any oils from pipe.
Mask off what you don't want painted. I hung some newspaper over the sway bar to keep it and the under body free from paint.
Put something under the area so you don't get paint on the floor.
Spray several, thin coats per instructions on the can.
Done. Wait for it to dry per instructions.
No warnings, pretty simple really. I also touched up the muffler cans while I was there.
thanx thanx, do i need to sand it down? is it a must? and also,
the oil and grease remover...is that a must too? cant i just clean the pipe well before painting?
thanx alots
thanx alots
I really didn't i just painted over the rust and most of the people on the cl fourm did as well. still looks good. only took about 10 min. Oh make sure you jack up the car. if its lowered. I also had a flatbed so it was easy for me to move around behind and under the car. and if it starts to rust again simply just paint it again. onlly 10 min process.
thanx alots
thanx alots
Even though I painted it flat black, the surface still looks nice & smooth a month later.
As far as prep work goes, it's all in how you want it to look. The more time you spend on prep, the longer the finished product will look good and the longer it will last.
BTW, NovaWhite, no offense intended.
hey thanx for ur helps! both u guys! and thanx for the pics!!!...
i like ur license plate casing... "type s"? where did u get it? and what does it say on the top? juss wandering...
Oracle Apps/Database Dude
I'm painting mine triple black (3 coats) this weekend. I anticipate 33.3 hp gain per coat. That is about 100 hp gain. That will bump me up to 325hp. BTW I'm also puting in mystery mod for an additional 50hp just for kicks.
WWW.ACURA-CL.COM, and on bottom it says TypeS.
I've also seen people do the typeS on bottom and have put the red comptech sticker on top.
Originally posted by rockinTLS
Looks good, NovaWhite. I was debating on going with gloss myself. Decided to go for that subdued, flat look.
What paint did you use?
actually its not glossy. I took that pic while it was still wet. now it look just flat colored
THANKS a BUNCH GUYS!.... with my bbq paint(1200degrees F)
and since i dont got a jack or anything, i juss stacked some wood blocks to make a ramp and then i went under it and just painted it about 4 times(coats)... it LOOKS GREAT!!! cause if i'm about 5 meters behind the rear the rusty y pipe is very noticeable... it didnt even take 10 minutes... like 5... i've just wiped the pipe with some towels and then just sprayed it... it looks great... and it really takes no time... I HIGHLY RECOMMEND on doing this... just go out to home depot or something and just by some bbq paint in a spray can...
thanx again and good luck!!
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
