About to give up on intake manifold cleaning
i'm about to give up on this upper intake manifold cleaning...
I have unhooked every hose and wire, and I have unscrewed every nut and bolt. Yet I cannot remove it from the TB or from the large black hose attached to the TB.
All the other threads just say to unhook everything, remove the bolts and pull up. But I can't get the plastic tube off of the TB. I have also removed those 4 bolts around that area, but the top two are just 'nuts' and the screw/bolt is still in there.
Am I supposed to just pull up on the manifold and hope it comes out of the black plastic hose/tube (and yes...i did loosen the metal fastner)?
if any of you who have done this can help me out, i'd appreciate it, otherwise I am going to put all together and wish I had spent my day doing something else.
thanks for reading
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
thanks for reading
thanks for the replies
As I look at different pictures and at my car, there seems to be two places to remove the mainfold from the rest of the car; before the TB or after.
When trying to remove the manifold with the TB, I would have to remove it from a large hose...but this is the big one, and there is no room to pull like the other smaller one. This hose, right next to the TB has a diameter like 5 inches. The intake manifold pulls straight up, but you can't pull it up with that huge hose attatched to it.
When trying to remove the manifold with out the TB, as I saw on some people's pictures then I would have to remove four bolts. The top two 'nuts' came off easily, as did the bottom two bolts. However the top two bolts are still in there spots (but with out the nuts). I don't know how to remove these screws/bolts.
am I even making any sense anymore?
Pics would help, but I think i know what your talking about.
1. Lossen clamps from TB & from the center of the large tube.(yellow highlight)
2. If standing on drivers side fender pull the large tube towards you & up. It will be tight but it will come off. You can also pull it away from the air box then completely remove it from the TB. Just remmember that it will be tight & dont worry about breaking anything that tube is strong.
![](https://i21.photobucket.com/albums/b295/optomos/tb.jpg)
thanks for the reply... yea you are exactly right...
but for SOME reason...my car (02 type S) has another metal something that is attached to the car which prevents me from pulling on it!!! I wish my car looked like your picture. =) cuz then i'd have no problems. but yea...i'm glad you were able to understand me without any pictures.
wow...you acurazine guys are awesome...
Sig Rho's Finest
They are throotle cables. One is the main cable, the other is the cruise control cable. Loosen one of the nuts that holde them to the metal bracket then pull back the throotle body lever to releash tension & push the cable to the right untill it comes out. The ends of the cable have a cylinder type tip on them that holds the cable in place.
ok...as I mentioned above...I did have to remove that final screw (i had to remove the battery to get to it...)
so yea...once that metal piece was loose, then I could pull back and easily remove the tubing/hose. ***but if that didn't work, I was going to just put everything back together and call it quits***
thanks for all the help...i'm kinda too tired to clean it now
if any of you are looking to do this, ask nathanli for his guide, it is pretty helpful and I wish I had it before I started yesterday...
here's hoping everything will run good when i put all back together
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
everything's all clean and put back together, but one last thing...did you put anything special on the gasket or did you just clean it w/carb cleaner and put it back on.
my uncle was saying to spray it w/something to help make sure it will seal well.
again...thanks for all the help and I look foward to driving it~
so i put everything back together...started the car..."maint rec'rd" light is on
but after 30 sec or so it turns off.
I drive out of the garage and park my car. I figure to restart the car again to see if the light comes on again. So I shut off my car.
Now my car does not start. The cabin lights come on. The horn works. The dashboard lights come on when I put my keys in. Headlights do not work. Car does not start?!?!?!
It can't be the battery b/c certain lights work. Maybe a connection got loose, I'll check tomorrow morning. It's too dark outside now.
It's pretty weird b/c the car ran fine around the block and now it does not even start.
cycdaniel
12-17-2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
