99 tl idle problem
99 tl idle problem
i just notice today when i started my 99 tl with 105k when my car idles its very rought does anyone know my problem how to fix it.
Originally Posted by Comet2404
Have you changed the spark plugs?
UB6IB9
Originally Posted by figueroa1357
yea,also changed oil,airfilter,trans oil,is anytrhing else i can do when it idles my sterring wheel vibrates and this just started before you could not even feel it when the car was runnig. thanks in advance
Originally Posted by 1st timer
could be one of the coils.
those things that you have to unscrew when changing you spark plugs,you have 6 of them,3 in front and 3 in the back.
if one those things go bad,your "check engine" light will go on.
Street Phazes
no check engine light but still rough idle when driving evreything is fine
How long has your car been like that? My check engine light didn't go on for about a week after the rough idle. Just bring it in to get an engine diagnostic test.
how do i determine which coil is bad
Street Phazes
Originally Posted by ricebox
Oh yea another recommendation for rough idle problems, you should check out BG Products Induction Service, cleans all air passages and cleans out carbon deposits, or you can try a nice can of BG 44k.
What cleaner did you use?
BG 44k is not just anyone fuel injection cleaner, trust me its a whole different level of cleaning, it is a total cleaner from gas tank, injector, chamber, catalytic converter, o2 sensor and so on. Trust me big ass difference. Oh yea for you guys out there that havn't had your transmission flush, check out BG's premium tranny flush and fluid. They got a cleaner during the flush and a conditioner additive after the flush. Nothing else out there even comes close. Best bang for the buck!
Oh yea to add, BG is not an off the shelf item that could be bought at wal-mart or your local shitzone.
Street Phazes
I put one can of bg44k in my car last week and all of a sudden it started to die. I asked a mechanic and he said that means you had a lot of junk that was being cleaned out. I have used other cleaners in the past but this one seems to be the best. I would definitly recommend this product..
UB6IB9
where else,canot find any on ebay.
Code:
http://www.ec-securehost.com/RynoPerformanceProducts/Featured_Products.html http://www.trademotion.com/partlocator/index.cfm?action=AccessoryCatalog&catalogid=3329&siteid=55&categoryID=42135
The main ingredient in that product is naptha. Back in the day with cars that had carburators, they use to pour a little tranny fluid down tha carb and that would eat up the carbon course thats kinda hard to do with a throttle body.(works great for an engine flush to )
This will help with carbon buildup, but the problem you are experiencing would not happen overnight...especially if you had this problem right after you changed the plugs.
What plugs did you use?(make sure they were iridium) Did you reset the computer? (disconnect both positive & negative terminals from the battery for a minute) Also look back over your handy work and make sure you put everything back together correctly. Check to make sure you didn't disconnect any vacume hoses by mistake, which is a taltale sign of rough idling.
Originally Posted by whatwasthat
.... what are coils?
SidhuSaaB
05-30-2020 12:40 AM
4drviper
09-23-2015 09:00 PM
