99 TL 6 speed swap help
Hey guys. I just got myself a '99 TL and I'm looking to swap the transmission since it slips really hard.
I've been looking at every swap thread I could find on this forum and I have to say, Phee's thread was probably the most helpful but I want to ensure I'm not spending any money I don't need to.
Can someone help me with which trannys I can fit in my TL & which parts I need? I may be wrong but from what I've found I think I can fit a tranny from the '03 CL-S, '04+ TL, '06-'07 Accord. Do I have any more options? Are there advantages of using one over the other?
Thanks.
Thanks.
Mr.Helpful Diagram
Heres the 6 speed thread
https://acurazine.com/forums/2g-tl-1999-2003-98/6-speed-conversion-591872/
All I know about those tranny is that the 03CLS has the LSD and the accord one didn't iirc.
https://acurazine.com/forums/showthread.php?t=591872
D'TL (12-10-2013)
You can use any of the trans you listed above, BUT if you use the 6 speed ecu from the CL you HAVE to use the CL-6 trans. Also i wouldnt use the accord 6 speed. It doesnt have the LSD and having the LSD itself is worth its weight in gold
D'TL (12-10-2013)
Would you go with the newer TL trans? The CLS is pretty hard to find and it seems every second car on the road is an 04+ TL. I'd probably find a tranny from that a lot easier than from a CLS.
Unregistered Member
However like Fatty said, if you use the true manual setup then you must use the CL-S6 tranny.
Probably easier and cheaper to find a lower mileage 04-06 TL tranny. Remember that the 07-08 TL-S6 trannies won't fit our cars at all.
D'TL (12-10-2013)
They are the same transmission with a slight difference for the crank sensor setup. If you use the AEM EMS 2, you can use whichever tranny you find.
Unregistered Member
You have three options for a 6 speed swap:
+True manual
-Uses all parts from the 03 CL-S6
-03 CL-S6 ECU
-03 CL-S6 Tranny
-03 CL-S6 wiring and sensors
+Richie Module
-Keep all your parts and just put in a tranny
-03 CL-S6 tranny OR 04-06 TL tranny
-Keep your auto ECU
-Keep your auto wiring and sensors
+AEM EMS 2
-Keep your auto ECU
Here are some Pros and Cons:
+True Manual
Pros:
-Works just like an 03 CL-S6 would
Cons:
-No tuning options
-Difficult wiring to get everything working (Moonroof, airbags, rear doors, gas gauge)
+Richie Module
Pros:
-Easy to install
-Keep old parts to save cost
-No custom wiring
Cons:
-No tuning options
-People have reported finicky behavior with the module
-Hard to get a module
+AEM EMS 2
Pros:
-Easy install
-No custom wiring
-Tunable
Cons:
-Custom work to get tach and coolant temp working
+True manual
-03 CL-S6 ECU
-03 CL-S6 Tranny
+Richie Module
-Keep your auto ECU
+AEM EMS 2
-Keep your auto ECU
+True Manual
Pros:
Cons:
-No tuning options
+Richie Module
Pros:
-Easy to install
-No custom wiring
Cons:
-No tuning options
+AEM EMS 2
Pros:
-Easy install
-No custom wiring
-Tunable
Cons:
So im guessing everyone goes with the CLS since its much cheaper, right? The AEM EMS 2 alone is 1,500$. Ive seen some people on this forum say they got a whole module for the 6 speed swap for under 1000$ sometimes.
Unregistered Member
Richie Module: $600
True Manual:
-$500 03 CL-S6 ECU
-$300 Engine Wiring Harness
-$300 Dash Wiring Harness
-$150 in sensors and gears
Price is pretty much the same for all of them. I guess Richie module is cheaper, but I don't think it's worth the problems people seem to get with them. Plus you can tune the EMS 2.
AEM EMS 2: $1100
Richie Module: $600
True Manual:
-$500 03 CL-S6 ECU
Richie Module: $600
True Manual:
-$500 03 CL-S6 ECU
Unregistered Member
Do you just pay full price for everything you look at lol? Just google a bit
http://kspecracing.com/i-328762.aspx
Thanks for all the help btw.
For 99 TL you going have to do some extra work with the wiring. The 99 TL harness is more like Accord ( 98-02) it took me 3 set engine to get done right. Really could done with only 2 but forget label all wire in my 1st set. The different is both speed sensor an temperature sensor.
mlody
12-04-2019 02:11 PM
joflewbyu2
10-08-2015 11:16 AM
xsilverhawkx
09-28-2015 06:51 PM
