'99 Headlights dim(ming)
I've got a '99 TL with 102K miles and I noticed that my lights, when first turn on, are that famous Xenon-blue. However, after about 15-seconds, both lights turn to a yellowish hue and stay that way. I know that the lights supposedly aren't supposed to go bad, but two things: First, how much do they cost to replace? Second, is there a way to tweak them?
Anyone else have this problem?
I love my TL too much to trade it in. Plus, I already have an '05...
Thoughts, please.
Thoughts, please.
I think it's normal, my TL does the same thing and has always been that way. Do your headlights put out the same brightness after they warm up? They are very expensive to replace so that's why they get stolen so often.
ChairmanMaoSaysRTFM
i could have sworn i've seen people say bad ballasts will cause this to happen. i would do a quick search to double check on this. could just be they are getting old. did it happen all at once or over time?
SSTS
SSTS
The dealer mentioned water may have leaked into the ballast, but I'm considering having it replaced. I envy the other TL's with the right light.
TLHottie,
Any idea how many hours are on your bulbs? If both headlights are doing it, I kind of doubt it is the ballasts (especially if it has been going on for 25K miles). New bulbs are about $70/pair on ebay. Do a search for seller akinaboy. You need to get the D2R version. Good luck!
Originally Posted by bigman
time for 6000k, my 99 did the same thing till they turned pink and died.
So, in this case - what do I do? I don't know a damn thing about installing lights -- but I would like something that might last a little longer (or would be just brighter than stock TL lights.)
What do I do? Or what should I be asking for?
I'm pretty dumb when it comes to stuff like this.
And, thanks for help, guys.
Originally Posted by phins2rt
TLHottie,
Thoughts?
The bulbs should last around 2500 hours. You won't find anything that last longer than Philips/Osram bulbs (OEM). You also won't find anything brighter than 4300K. Swapping out the bulbs will give you more white light.
Need bulbs? I can help you. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
I have philips 4300k(standard bulbs) or 5000k(philips CM) bulbs, which are slightly whiter and bluer but not much different from 4300k bulbs.
Akinaboy, i need new bolbs..email me remy912@mail.com
soupi
14
11-15-2015 11:15 AM
