7500k
Old Jul 5, 2004 | 02:55 PM
BIG_KOUT's Avatar
7500k
I'm looking into the PIAA plasma blue spark 9006 bulbs for my foglights..... this is a 55w bulb but has anyone had any problems with the 7500K melting ur fog light assembly or housing?
thanks
Old Jul 5, 2004 | 04:02 PM
Tatewaki's Avatar
given it's PIAA and not some cheap brand, should not be a problem
Old Jul 5, 2004 | 10:55 PM
BlackShadow's Avatar
O.G.
55 watts is the maximum I would go for the fog lights.
Old Jul 5, 2004 | 11:03 PM
Bxscig's Avatar
I think that 55Ws are fine, with no melting. It may fog a little if the weather is bad with the extra little heat.
Old Jul 5, 2004 | 11:46 PM
Davidlamny's Avatar
I'm using PIAA 5000k Super Plasma which has a HID look, but not bright.
I think it might be a lot less bright for the 7500K, and should be very blue!!
So, I would recommend 4700K Xtreme Force!!
By the way, where did you find the 7500K(online store)??
Old Jul 6, 2004 | 11:39 AM
BIG_KOUT's Avatar
yeah the 7500k are imported from japan online, unfortunately they are on backorder everywhere. So your saying the 7500k will not be closest to our HID look but not crazy bright? I can deal with that. As long as they are brighter than our stock bulbs geez
Old Jul 6, 2004 | 03:06 PM
Davidlamny's Avatar
Do worry!! It will definitely bright than the stock!! Of couse, you can't compare the brightness with the HID. That's a different story!!
I know Piaa has good stuff, but there is a name "RAZO", also makes good light bulbs. You could try their PREMIUM WHITE ZERO 4550K which I'm using for my high-beam now. They have 9006 bulbs for 02-03 too. It's one of the whitest, brightest and cheapest(comes around $55) bulbs I have ever seen!!
I was doing some research of Piaa 8000k and 7500k light bulbs too, I just gave up becaue they always said they are back order from Japan. :o
Old Jul 6, 2004 | 03:38 PM
Bxscig's Avatar
Go with HIDs for the fogs if these dont last cause in the long run, the HIDs are a much better investment.
ndub
2G TL Photograph Gallery
Jul 12, 2009 02:26 PM
Acura604
3G TL Photograph Gallery
Mar 26, 2009 08:47 PM
terry919
Nov 29, 2008 07:23 PM
`ill*tl
Mar 14, 2004 03:20 AM
