6 speed conversion, 2nd problem 9/2/17
Old Mar 19, 2007 | 10:14 PM
  #1081
3TL's Avatar
3TL
fsttmys. so i have the transmission. and just saving up for all the necessary parts. clutch, flywheel, shift linkage, etc. how long did it take you to install everything? days, weeks, months? where did you get the whole cl interior assembly?
Old Mar 19, 2007 | 10:22 PM
  #1082
joe80055's Avatar
Oh shit, you're doing it too?.. good luck
Old Mar 20, 2007 | 07:31 AM
  #1083
fsttyms1's Avatar
It took me months. I slowly bought parts and i was out of town working alot. If i had ALL the parts and then started i could have done 95+ % of it in a weekend.
I didnt get the whole CL interior assembly. My interior is stock TL other than the gauges, parking brake, and cup holder. Read the 2 threads to see what was used, the parts list and pics
Old Mar 20, 2007 | 12:42 PM
  #1084
joe80055's Avatar
At the moment, it's been less than a month.. so far and I've got the bulk of parts.. it's just the little things here and there that'll have to save up to get. 3TL, how much did your transmission cost you? If you already have the type-S, this will be one damn cheap mod for you compared to the amount we're spending. lol
Old Mar 21, 2007 | 08:35 PM
  #1085
3TL's Avatar
3TL
with shipping the transmission cost me close to 2 grand. my tl is not a type s. I still need to get a Exedy stage 2 clutch and fly wheel. im basically rebuilding the engine too, so it going to take me longer along with the JE pistons, crower rods, etc. but once i get started with all parts i'll keep you posted.
Old Mar 21, 2007 | 08:41 PM
  #1086
joe80055's Avatar
SHIT.. where'd you get your tranny to be so much?.. I only paid $1,400 shipped. Keep us updated
Old May 5, 2009 | 02:38 PM
  #1087
jproy's Avatar
MP90 uninstalled
Did you ever put together a parts list for this thread? I was wondering if you had to swap the two TDC sensors behind the front Cam plate from the Auto sensors to the Manual sensors in addition to the front cam pulley? Thanks
Old May 5, 2009 | 05:38 PM
  #1088
fsttyms1's Avatar
Yea the parts list is in the stickied one. But to answer your question yes, i had to replace the 2 TDC sensors
Originally Posted by fsttyms1
Well I finally threw together a parts list. There were some misc bolts used, but i got abunch of them from the local hardware store grade 8s)
Engine. J32A2 If needing a new engine look for a CLs-6 motor (if not see below *)
03 CLs-6 speed manual.
03 CLs-6 Manual Engine Harness. 32110-PGE-A11
03 CLs 6 speed ECU
03 CLs-6 Flywheel 22100-PGE-026
03 CLs-6 Flywheel bolts (Qty 8) 90011-PGE-000
03 CLs-6 Clutch Assembly 22105-PGE-305 (unfortunately right now there arent many options for aftermarket clutches)
03 CLs-6 Rear Engine mount and bracket 50810-S3M-A01, 50827-S3M-A00, BOLT (m12X25) 90166-S3M-A00
03 CLs-6 Rearand Front Engine Dampenerand bracket (i would reccomend aftermarket here)
03 CLs-6 Shifter and cables. 54100-S3M-A01, 54310-S3M-A01
03 CLs-6 Starter 31200-PGE-A11 (try to locate used, its expensive)
03 CLs-6 Gauges
03 CLs-6 Hydraulic Clutch lines. 46960-S3M-A01, & 46970-S3M-A01
03 CLs-6 Trans mounts (2 of them) 50806-S3M-A03, 50805-S3M-A03
03 CLs-6 Cup Holder 77230-S3M-A01ZA
03 CLs-6 Parking brake 47105-S3M-A04ZA and to go with it,
Spring 47537-671-670, Nut 47522-594-000, Equalizer pin 47365-538-000, Equalizer 47360-SB2-000
*If you use the J32A2 from the Auto you will need these parts (all from the CLs-6)
Front cam pulley 14260-PGE-A11
Front plate assembly (behind cam pulley) 11860-PGE-A10
Timing belt pulley(lower) 13621-PGE-A11
Crank shaft sensor 37500-PGE-A11 (this little shit costs $500.00)
Subharness for CKP 37501-PGE-A10
TDC Sensors (Qty 2) 37840-PGE-A11
TDC SUB HARNESS 37841-PGE-A10
If you dont already have the Type-s you will want the IMRC 37850-PGE-A01
Brake/Gas pedal assembly from either the accord or CLs-6. (i modified mine)
If you decide to buy it new BRAKE PEDAL ASSY 46600-S3M-A51
Clutch pedal. (this can be from a few cars, i took mine from a 90s civic. it was almost a direct bolt in.
It uses 3 points to bolt in only 2 lined up. I modified a bolt and shim to make it bolt up in the 3rd spot)
If you decide to buy it new you will need the pedal and mount CLUTCH PEDAL 46910-S3M-A01 & CLUTCH PEDAL BRACKET 46990-S84-A01
MASTER CYLINDER ASSY 46922-S3M-A01 & Clutch Fluid Tank 46965-S5A-013, & Clutch Hose 46961-S3M-A02
(i used the one from the civic i pulled the clutch pedal out of)
Things im not sure if you will need but i bought.
Relay box assembly (under hood) 38250-S3M-A21
Shift Boot 83414-S3M-A01ZA
Shift Knob 54102-SL0-023ZB
If you have a header you will either have to have the XS header or COmptech header for the manual. Other wise it wont fit
You will be able to reuse the stock manifolds
If you already ahve a Type-s you MAY Not need these????
Right side cabin to engine comp harness 32100-S3M-A12
Left side cabin to engine comp harness 32120-S3M-A20
I Would attempt with out (that i bought and used with out trying without first) It will make not having to do all the rewiring of
that i did.
Upper instrument harness 32117-S3M-A31
Lower dash harness 32150-S3M-A32
Old Oct 27, 2009 | 06:32 AM
  #1089
Ep3moschini's Avatar
Like a BOSS
so can you use any maual trans from a J-series or will it have to be from the CL-S???
I can potentially get a hold of a 3g TL-S 6mt and I was just wondering if it will work
Old Oct 27, 2009 | 06:38 AM
  #1090
juanclopez2786's Avatar
yes itll work
Old Oct 27, 2009 | 09:17 PM
  #1091
INSPIRE 32V's Avatar
Glacier Frost Mica CL-S
i have a major problem. i used a 04 6 Speed tranny in my 03 CL which was already a 6 speed but i changed my tranny because i had bent shift forks and what not.
anyways the 04 tranny does not seem to have a senser on the top that the orignal CL tranny had so because of that my car is stuck in safty mode and wont let me rev any higher than 2K RPM's.
Old Oct 27, 2009 | 09:35 PM
  #1092
Here is a pic of the sencer that the original 03 Tranny has but the 3g Tl Tranny doesn't have
Old Aug 25, 2010 | 01:45 PM
  #1093
fsttyms1's Avatar
Well today i had the first problem with the 6 speed. I had the Slave Cyl go bad on me. It was kinda fun driving 20 miles with no working clutch....
Though it was a easy 15 min fix including the bleeding.
Old Aug 25, 2010 | 04:21 PM
  #1094
assclown's Avatar
2000 acura tl FPR
haha congrats kris. what has it been? almost 4 years?
Old Aug 25, 2010 | 07:08 PM
  #1095
fsttyms1's Avatar
Yep, only wish i had done it 4 years sooner
Oh and its got the same clutch at over 100k with many lapping days. The ONLY trans Honda knows how to build is a Manual trans!
Old Aug 25, 2010 | 07:13 PM
  #1096
assclown's Avatar
2000 acura tl FPR
yes sir. my clutch will prob wear out before yours
Old Oct 28, 2010 | 08:42 PM
  #1097
Type JDM's Avatar
CL-S 6MT Navigation
Hey whats up guys? I have a little problem. This is my second 6 speed swap that I have done.
The first I used Richies harness.
The second is the one im working with now which I went the other route and purchased the CLS6 wire harness,ecu, and sensors. But the problem is I have 4 wires that my 01 CLS does not show in the ETM.
First: yel/blu (vcc3)
Second: blk/red (sg3)
Third: wht (rvslck)
Fourth: blu/wht (clsw)
I also can't get the car to turn over.
Any ideas on what I've missed? Thanks guys.
Old Oct 28, 2010 | 09:50 PM
  #1098
assclown's Avatar
2000 acura tl FPR
not sure man, did you get the key programmed to that ecu?
are you helping derrick "tlbadboy96"? he's in va beach doing a 3.5 6mt swap right now too
Old Oct 29, 2010 | 05:45 AM
  #1099
Type JDM's Avatar
CL-S 6MT Navigation
I havent programmed the ECU yet but thats not the main problem.
Yes the immoblizer light is flashing.
But its not cranking at all like if the clutch pedal has to be pushed in. (No turning over sound / engine not rotating)
Old Oct 29, 2010 | 07:55 AM
  #1100
assclown's Avatar
2000 acura tl FPR
have you tried messing with the park/neutral safety switch?
Old Oct 29, 2010 | 11:13 AM
  #1101
Type JDM's Avatar
CL-S 6MT Navigation
I no longer have one since I did the complete 6 speed engine harness, crank pulley, front cam pulley, with all sensors.
Old Nov 4, 2010 | 05:48 PM
  #1102
jwerks's Avatar
8th Gear
That's tight looks good
Old Apr 5, 2011 | 10:28 PM
  #1103
Cross Bronx's Avatar
5th Gear
I need to see the pic can you repost are show me were to look for the pic. Nice
Old Apr 6, 2011 | 08:00 AM
  #1104
phee's Avatar
I got the Shifts
Program your key
Old Apr 6, 2011 | 10:38 AM
  #1105
fsttyms1's Avatar
Need to see what pic ????
Old Apr 6, 2011 | 11:15 AM
  #1106
phee's Avatar
I got the Shifts
what were the symptoms of a bad slave?
Old Apr 6, 2011 | 01:56 PM
  #1107
fsttyms1's Avatar
When i pushed it the pedal went to the floor and never came back. Its like brakes after changing a caliper. Until you bleed the air out and get fluid to the caliper the pedal doesnt really move with much feel (only reason it has any feel in brakes is there are 3 others putting some pressure back)
Old Apr 6, 2011 | 02:06 PM
  #1108
phee's Avatar
I got the Shifts
my clutch pedal is hitting the ceiling on hard shifts and its driving me nuts
Old Apr 6, 2011 | 02:12 PM
  #1109
fsttyms1's Avatar
Hitting the ceiling??
Old Jul 5, 2011 | 10:52 AM
  #1110
ktec2's Avatar
5th Gear
hey guys just completed my 2gen 6 speed swap in my tl but its in limp mode i need help on getting it out
Old Jul 5, 2011 | 03:04 PM
  #1111
reese8789's Avatar
Details on the swap are needed. LIke what motor are you using /engine harness and ecu.
Old Jan 12, 2012 | 02:32 PM
  #1112
Boulder's Avatar
Epic car......epic thread.......e.p.i.c.!!!!!!!!!!!!!
Old Jan 13, 2012 | 10:42 PM
  #1113
Scott555's Avatar
3rd Gear
I'm curious too. I'm about to swap my 03 TL-S since the auto trans just died. Getting all the info I can up front.
Old Jan 14, 2012 | 01:45 AM
  #1114
sl33kTL's Avatar
Not sure I understand what youre saying. Did you read all these pages???
Old Feb 8, 2012 | 02:43 AM
  #1115
andrewl01's Avatar
6th Gear
About to start my 01 CL-S conversion to 03 CL-S 6sp too!
Were there any issues besides the slave cylinder?
Old Feb 15, 2013 | 09:25 PM
  #1116
heybeni's Avatar
if mine already has the type s engine do i need to replace it.??
Originally Posted by Xenologics
fsttyms1 your my hero.
When my auto tranny went last month I was thinking about asking em to install the 6 speed tranny instead. I doubt they would do it.. I haven't heard of anyone that has changed it to the 6 speed.
Can't wait to hear about the results. Keep us posted with pics too!
Good luck
Old Feb 16, 2013 | 08:23 AM
  #1117
fsttyms1's Avatar
No. Just need to swap the cam sensors/cam gear, lower crak position sensor and wheel. And switch over to the manual engine harness.
Old May 31, 2013 | 06:02 PM
  #1118
swordtwo's Avatar
6th Gear
6 speed conversion
Got it for 1500 shipped. and yes ill replace it
I have an '03 CL-S w/108k; 50k on 2nd tranny.
I want to know where to order a 6 speed conversion tranny?
THX,
swordtwo, Orlando FL
Old Jun 5, 2013 | 01:01 AM
  #1119
AcraAdi93's Avatar
THX,
Not worth it unless you got the extra cash. Luckily in your case they made the CL's in manual in S 6 speed. If it was a TL then yeah why not
Old Dec 23, 2013 | 08:15 PM
  #1120
luna1128's Avatar
Hi , I have a 2003 TL Type S and i am planning on doing this 6 speed swap . What would I need and how much do you think it would cost? Would I just have to bolt on the new transmission ? as far as engine/transmission goes
