4th Gear Fix
Old Mar 19, 2010 | 05:00 PM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
4th Gear Fix
Yes, I know the standard 'fix' is to do the 6-speed manual transmission swap, but I investigated another option today.
I called the transmission shop where I have taken vehicles in the past to ask a question. This is not a national chain transmission shop, but rather a local, well-respected shop that many engine shops refer customers to for tranny work. I asked whether the 4th gear alone could be swapped-out in our cars.
As many of you know, 4th gear in the 5-speed automatic transmissions in our cars really sucks. 3rd gear has a 1.021:1 ratio, then in 4th it drops to 0.653:1 (0.727:1 type-s), then finally in 5th it goes to 0.470:1 (0.520:1 type-s). So, in 4th gear you are already into a substantial over-drive situation, which is meant for better gas mileage, not performance.
So I thought to myself, "Self, I wonder if it would be possible to swap-out just the 4th gear with a better-adapted gear that has a closer ratio?" The short answer is 'yes' according to the transmission guy.
He said that Honda trannies (no, not chicks w/d!cks) are one of only a few manufacturers (including Subaru and some Saturns) that use gear-on-gear technology in their automatic transmissions. From my understanding, this means that Honda/Acura automatic transmissions are built like manual transmissions in design, but operate as automatics. This is one reason that they are more expensive to work on. Being designed that way, he saw no reason that a specific gear (like 4th gear) could not be replaced. Of course procuring that gear could be a challenge, but if obtained, he said it could be swapped-out.
Labor would be intense, though, as he said rebuilding a Honda tranny takes 18-20 hours. He added that there would be other supplies needed such as gasket kits, internal filter, etc., but it is all doable if someone wanted it done. At $50/hr, that would be around $1,000 just for labor, plus supplies and of course obtaining that new 4th gear...somehow.
This may not be a viable option, but I thought it was at least interesting.
Old Mar 19, 2010 | 09:04 PM
01tl4tl's Avatar
if you are that desperate for a different gearing, go buy a used race car and take it to track days for some real fun
You can get a decent racer for the price of screwing around with the TL
Old Mar 19, 2010 | 09:51 PM
fsttyms1's Avatar
you change 4th you might as well change 5th. The jump from 4th to 5th would be unbearable. 4th isnt that bad if you manually run 3rd to redline, you stay in vtec once in 4th and the acceleration isnt that bad.
And yes, the honda auto is a 3 shaft design that is just like a manual trans.
Old Mar 19, 2010 | 10:15 PM
gold2003tl (90)'s Avatar
2003 TL-p
^ wait there arn't any engagement of meshing gears in the auto right? kinda hard to picture an auto set up like a manual, meshing gears just come to my mind.
Old Mar 19, 2010 | 10:20 PM
ANC297's Avatar
Bonki' Ehrite!
If it'd cost approx a grand, why not put that money into a fund for 6spd swap? And get the full performance throughout all the gears
Old Mar 19, 2010 | 11:05 PM
jdjohn84's Avatar
Not desperate...just curious.
True about 5th. Yeah, I know about redlining in 3rd, but I hate to redline if at all possible.
I don't see myself doing either at that price. I was just curious as to whether it could be done. However, changing the auto would be less invasive than the 6sp swap, and I drive in too much rush hour traffic to enjoy the manual anyway.
Another option would be to change the differential, but that would affect all gears and still require a rebuild. I guess I'll just enjoy running 3rd gear up to 70 or 80mph, then hope I'm ahead.
Old Mar 20, 2010 | 07:08 AM
fsttyms1's Avatar
Why not, you arent going to hurt the motor.
Old Mar 20, 2010 | 11:45 AM
03tLsNBP's Avatar
MechEng
how so? i thought redlining was not healthy for the engine.
Old Mar 20, 2010 | 12:08 PM
fsttyms1's Avatar
Because we have revlimiters to keep us from harming the motor.
Old Mar 20, 2010 | 03:33 PM
hANDYcaptd's Avatar
It's the Halladay season!
^ You'd just bounce off the rev limiter. It won't go high enough to harm the motor.
Old Mar 20, 2010 | 03:43 PM
jdjohn84's Avatar
It might not break on the spot - first time or fiftieth time - but probably shortens the overall life of the engine. You gotta figure any engine has a finite number of RPMs in it, so you would reach the engine's end-of-life faster the more often you rev it that high. You would also have to do valve adjustments more frequently if you redline it often.
Old Mar 20, 2010 | 04:20 PM
fsttyms1's Avatar
Ummmm No. The whole point of the rev limiter is to protect your motor from going to far. You wont hurt it. Mine hits it many times a day. (1st gear comes so fast with the 6 speed its not funny, plus on track days) I havent needed a valve adjustment in the 340,000 miles of driving yet, nor have i taken any life off the motor. If it was bad for the motor to rev to the revlimiter they wouldnt build the motor to do so.
Old Mar 20, 2010 | 04:42 PM
jaMezBOI's Avatar
philly flickin'
That's true.
I can't believe you haven't needed a valve timing in that long. I've had to do it twice since I've had the car.
Old Mar 20, 2010 | 08:40 PM
fsttyms1's Avatar
Originally Posted by jaMezBOI
That's true.
I should have added the first motor didnt need it when i pulled it out for the swap at 220k, this motor has near 200k on it and doesnt need it either. (though i did check them one day and they were all in spec)
Old Mar 20, 2010 | 09:30 PM
jdjohn84's Avatar
Can we send you the bill if we throw a rod? Seriously, what was wrong with your first motor that required a swap? Too many redlines?
Old Mar 20, 2010 | 09:41 PM
jdjohn84's Avatar
I know you did the 6-speed swap as well. Did you kill an automatic first? I know they are more fragile, so redlining might put them in further jeopardy.
Old Mar 20, 2010 | 09:47 PM
fsttyms1's Avatar
Nothing was wrong with my motor, i wanted the type-s motor.
I went thru 5 trans. Redlining them had NOTHING to do with them failing.
Nor is it going to cause you to throw a rod
Old Mar 20, 2010 | 10:26 PM
jdjohn84's Avatar
That's right, you did the 6-speed swap and the engine swap at the same time. I don't doubt anything you've said, but I just have a fundamental problem (fear) redlining. When I did my post-Sea Foam blow out run, that was the most I have probably ever revved a car in my life. But I must say it was fun to see how fast my car could go in 3rd gear. It definitely gave me more confidence to rev 5,000+.
I also enjoyed toasting a riced-out Prelude from a traffic light later that day He never saw it coming from my stock TL-S. I would back off, and he would try to pass...I don't think so.
Old Mar 21, 2010 | 09:33 AM
fsttyms1's Avatar
LIke i said earlier, if it was bad for the motor they wouldnt have designed the motor to let you go that far.
Go out and play, its a HONDA, They love to Rev HIGH!
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
NitroViper
Mar 20, 2017 09:50 PM
justin7779
Dec 25, 2015 10:33 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
kuzdu
Sep 10, 2015 08:42 PM
