3rd time changing 02 Sensors - Whats wrong?
The Talk of New York
![Arrow](https://acurazine.com/forums/images/icons/icon2.gif)
So I've got an 02 TL-S with a Tanabe Super Hyper Medallion Exhaust, OBX Headers, AEM CAI, and a High Flow Cat...
In the past year I've constantly had codes P0138, P0141 along with a few other ones I cant remember right now.
I've changed the damm 02 sensors like 3 times already, and each time everything works good for a few months, and the CEL comes back on with the same damm codes, Bank 1 Sensor 2 saying something about high voltage
The first replacement 02 sensor I got was Bosch, not the crappy universal one, but the one that plugs in. The CEL never went away for that one, so I ended up going to a cheap mechanic who put in a cheap plug in 02 sensor that actually made the CEL go away. It lasted until I was driving on the highway and a huge metal pole fell off the back of a truck and I ended up driving right over it cause didn't have time to avoid it...ripped the 02 sensor right out, and took 2 of my rims with it.
I then put in some other OE replacement sensor which worked for about 6 months...and now I got CEL P0138 + P0141, on top of all that my exhaust is making a very loud humm, almost sounding like a vacuum cleaner, I was at an exhaust shop a couple of weeks ago, and there was a leak in the middle area, but it was fixed up by tightening the bolts.
So now I'm getting ready to get new sensors but want to make sure that the core problem is fixed. I'm inclined on getting Denso sensors, # 234-4727 & # 234-4261
Anybody got any ideas on what else could be causing this very annoying issue?
OEM from acura are made by Denso, only difference is if you buy them from acura then you pay like 3 times more, I found both of them for $110 shipped online...
give Josh at Excelerate a call or PM with specs and prob- he knows this stuff.
plus you had a leak- thats going to screw with several sensors and you may need a obdi that clears codes or try an ecu reset by pulling the CLOCK fuse
passenger side in cabin-#12 or 13 iirc- remove for a minute
Many people have to use a `spark plug oil protector` 5 bucks at parts stores- for the O2 sensor- its a tube that moves the spark plug out slightly from normal and covers its end to protect from oil dripping off bad valve seals--causing fouling
its old school car fix for chevy problems
With the increased flow rate you may be fooling the sensors so this shroud compensates and slows the air
alright, i guess i'll have the shop take a closer look at the exhaust from beginning to end
Also, Denso is the OEM company used by Acura for the 02 sensors, so I dont see how it should cause any problems, whether i buy them from acura for like triple the price or online and save some money....
B A N N E D
ok so im going to the mechanic today to get the sensors replaced, I have both Denso 234-4621 and 234-4727
can anybody please tell me where each sensor goes as per the diagram below
![](https://img63.imageshack.us/img63/8295/exhaustr.jpg)
5 bucks or so for the anti fouler from any parts store in your town
If your tech cant figure out which ones need replacement and that they need the anti fouler- go somewhere else!
like a place that WORKS ON HONDAS AND ACURA NORMALLY
Do you have a different cat on the car? Your cat may be causing the issue. Even if your stock it may be the problem. Your ECU may also be the problem.
mada51589
05-03-2022 08:54 PM
Skirmich
09-15-2015 06:41 PM
