2003 TL Type S 1&5 Misfire
Old Feb 28, 2011 | 08:04 AM
yoofamily's Avatar
Please help! Purchased my 03 TL 2 weeks ago and it's been in the shop since! I replaced the timing/water pump and adjusted the valves. Still getting misfire error on cylinder 1 & 5. My mechanic (friend of mine) tried everything. Installed all new coil packs and same problem so returned the coil packs. Tune up was done (all new plugs). Car runs fine on the road. Just at idle very rough and check engine, vsa, "!" lights remain on. Can't pass emissions with this problem obviously. Can anyone help out there? He even spoke to Acura to reach out and they are clueless as well. Will reflashing the ECU solve this problem? Thank you!
Old Feb 28, 2011 | 09:42 AM
fsttyms1's Avatar
Has any one done a compression test? that would be the first thing i look at next. What is the fuel pressure? has that been tested. You really cant reflash these ecus. If one is bad it needs to be replaced.
Edit one more thing to look at is the Fuel Injectors.
Old Feb 28, 2011 | 11:34 AM
01tl4tl's Avatar
what spark plugs did you install,,, ngk irids ngk plats???
or some 2 buck chuck =wrong plugs in the TL~
pull a few now and inspect wear--that tells whats going on inside the engine
Old Feb 28, 2011 | 11:35 AM
01tl4tl's Avatar
if the coils were tried without resetting the ECU- you got bad info still
must reset! --use clock fuse
Pham Alvan
Mar 16, 2016 09:17 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
Ponsey_Scheme
Oct 23, 2015 09:16 PM
STL TL-S
Sep 23, 2015 08:52 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
