2003 Timing Belt?
Timing belts need to be changed every 100,000 miles or 7 (?) years unless there is considerable wear. The only way to find out if there is wear is to visually inspect it, and if you're going to look at it, you might as well change it since it is a pain to access.
Change the water pump if you're going to change the timing belt.
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
