2002 tls braking issues
Old 05-05-2001 | 11:07 PM
tls260
Guest
Posts: n/a
Thumbs down 2002 tls braking issues
I recently purchased a 2002 tls and noticed the brakes feel soft and mushy does any one else have the same problem?
Old 05-06-2001 | 12:51 AM
bdimc2001's Avatar
Talking
I think the 2001 is like that also, I don't really like the feel of the brakes at all. Maybe b/c I'm always going too fast.
Old 05-06-2001 | 09:40 AM
[VTEC]TL's Avatar
RWD convert
Post
It could be a mechanical problem. My 2000 TL brakes got really mushy so they replaced the master cylinder.This made the brakes much stiffer. Then it got soft again so they bled the brake lines. This fixed the problem, but brakes kept getting mushy. Finally after bleeding the lines 2-3 visits in a row, they replaced my ABS control unit, I think, and so far no more saggy brakes, knock on wood.
Y2K Satin Silver/Ebony 3.2TL
-AEM Short Ram intake
-Magnaflow axle-back exhaust
-Ground Control coilovers
-BLITZ coolant pressure riser
-BOSCH platinum+4 plugs
-Factory underbody kit and Wing
-Mesh grill
-Body color door handles
-Lighting:Polarg M12 sidemarkers/Opti-Blue Xenon HighBeams/Eurolite 168 Xenonbulbs/Minimax Xenon domelight/Hiper Strobes
-20%/35% Llumar Platinum tint
-Räzo Shifter and Alloy pedals
-2 Rockford 10" XLC subs pushed by Boss Audio CLR60 amp
-Escort Passport 7500
Old 05-06-2001 | 11:48 AM
Pimpin_TL's Avatar
Post
I think brakes are an issue with all Gen 2's..
my 99 squeals like crazy
Old 05-07-2001 | 12:11 AM
Shoofin's Avatar
Post
The tires.. Change the tires....... My plans are cross-drilled or slotted rotors with Metal Master pads and some goodridge brake lines, that should help just a bit...
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech Springs and Sways, CL Type S wheels wrapped with 225/45/17 Dunlop SP9000's, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, Gutter Guard Grille, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
mada51589
05-03-2022 09:54 PM
02tljj
09-11-2015 01:37 PM
kuzdu
09-10-2015 09:42 PM
HOWELLiNC
09-10-2015 02:39 PM
ellisd03tls
09-08-2015 05:17 PM
Quick Reply: 2002 tls braking issues
