2002 tl transmission
FAQ: 06-07 AV6 Transmission 'Swap' - AcuraZine - Acura Enthusiast Community
2) If you are mechanically inclined & want to 6speed swap your automatic TL to a manual transmission you should first obtain a 'donor' car, since many CL-S6 parts are discontinued and not available.
That way your probability of success is higher since the donor car will supply what you need.
3) Otherwise, stick with the automatic AV6 swap listed in #1 above.
