2001 Acura TL Driver Side Lowbeam
Old Jan 21, 2019 | 09:12 PM
User 12221's Avatar
Hi all,
I was looking to replace the low beams on my 2001 Acura TL. I am able to do the passenger side but unable to reach the driver side. There is this pipe between the battery and air filter that is preventing me from reaching the low beam. I tried tugging it to the point where the car is being slightly lifted but it will not budge. I tried referring to this guide by fsttyms1 but the pictures have been removed. (https://acurazine.com/forums/second-...lation-631575/)
Any suggestions? Thanks!
Alternate Image Link: https://imgur.com/a/h1cCJQa
Old Jan 22, 2019 | 09:38 AM
Saudade's Avatar
USAF Veteran
Veteran: Air Force
It does just pull out. There are little tabs that snap into the mating sides to hold it on.
When I cleaned the screens in my trans solenoids I had to take out the battery and box as well as the air cleaner. That vent popped off with some slight twisting.
You likely have years of crud accumulated making it more difficult.
Here's an exploded diagram showing the parts.
https://www.acuraoemparts.com/auto-p...er=17216pn3000
Old Jan 22, 2019 | 10:18 PM
User 12221's Avatar
Thanks! I took your advice, got a flathead screw driver and pried the tube loose.
There seems to be a delay on the driver side light. When starting the car, it takes a few minutes for the driver side lowbeam to turn on. I thought replacing the bulb would fix it but it didn't. Any experience with this?
Old Jan 23, 2019 | 09:46 AM
Saudade's Avatar
USAF Veteran
Veteran: Air Force
So the passenger side lights quickly? What about switching from low to high beam and back to low?
Could be the ballast.
Old Jan 23, 2019 | 01:22 PM
User 12221's Avatar
The passenger side lights up immediately. High beams work perfectly as well. After reading this thread (https://acurazine.com/forums/second-...roblem-781734/) I think it might be the ballast as well.
Thanks!
neubert24
1G TSX Problems & Fixes
14
Nov 19, 2014 01:08 PM
joelmatt89
May 3, 2012 07:17 AM
phishfood
Aug 28, 2011 05:58 PM
EMT
Jun 16, 2011 08:09 AM
pharmgeek
Nov 6, 2007 09:57 AM
