2000TL Tune Up
2000TL Tune Up
Hi guys I have been looking around and trying to figure out what needs to be done to my TL. I bought it with 125k and now am I around 155k.... All I have done is change the oil.
I found the thread about NGK Iridium IX spark plugs... Awesome DIY
But I am curious what I should do about the tranny because I am sure the oil needs to be changed, but it runs fine so I don't want it to blow up
So should I just drain and full the oil? I found a thread that says put it 3 quarts then drain and do it a couple of times which is kinda confusing..?? Seems easier to just drain and fill
Anything else that needs to be done?
You dont fill then drain, you drain then fill it back up. Typically 3-3.2 quarts come out when you drain. The trans holds near 8 quarts. that is the reason to drain then fill doing it 3 times. You get more of the old out and new in. Do NOT flush
Has your timing belt been replaced yet?
yea I should have proof read my post lol... I understand drain then fill, but my concern is having problems with the tranny after messing with the oil. I'm scared to death that it will blow up and wondering if I should just leave it alone since it runs fine. Also I would need to buy 12 quarts which is kinda spendy,.
I'm not sure what has been done, all I know is I bought it at 125k and put 30k on it and haven't done anything but oil change. Runs great
do NOT do a 12 qt flush= trans death for older units
3 qts one time- thats it
best thing is a 3 ounce oil sample to lab for analysis- www.blackstone-lab.com for info
Will tell you if the clutches are disintegrating or ok
register with acura- make sure the oil jet kit was installed under recall and see if you are part of the airbag inflator recall
1-800-382-2238x5
caution -the azine curse- dont state your miles and how great trans is--ever seen scary movie? starts the countdown clock
remove a spark plug and see how old it looks- indicator of 105 service from that,
and look at bolts for timing belt covers for signs a wrench/socket touched them at some point
1-800-382-2238x5
well I had to call both Acura of Canada and USA to get information, but my car does have the recall for the 2nd gear. Either I get the oil kit or the my tranny replaced if there is a problem.
Somehow my car made it to the states without having the recall done and my local Acura said they can't do anything cause its a Canadian car... After calling both Acuras I finally got the US Acura to give me a case number and I'm waiting to hear back.
Is there anything I can say or do to help my local dealer with the recall and get a new tranny so I don't have to worry about it? I don't wanna lie but my car does shift kinda hard and just doesn't seem right.
I would much rather get a news trans then the stupid oil kit
if its a usa car- usa dealer needs to handle
if canada car- canada acura
they are different companies
of course the car qualifies for the recall - but was it ever done??
verify you dont have the recall installed oil jet kit
look at top of trans where filler bolt should be
if a large bolt with ATF marked on it is there- no oil kit
If a small black line goes to a funky thing in that hole, held on by a 12mm bolt (see numerous pics with search) then it has the oil jet kit
Also look under car at trans end- main bolts going thru trans will have blue painted bolt heads on warranty replaced units, cant miss them either~
the good news!!- if specific damage from heat is found in the right areas, it turns into a warranty replacement trans
dealer uses a boroscope camera to examine for heat damage to 2nd gear
There is nothing for you to say to make it worse- its bad or its not
assuming canada car it will be easier to get warranty done there
At 155k miles and 10 years your TL is way past the 100k (or 109k due to the odometer issue) mark for the tranny replacement. Hopefully you've been going to the dealer for your oil changes because you'd have to rely on goodwill.
Maybe you purchased an extended warranty?
as said above- the recall install of oil jet kit turns into warranty unit replacement
IF certain heat damage is found with a boroscope camera
IF thats the case, regardless of miles or years, its going to be easier to get approval if in the country of origin
safety recalls dont expire
MrHeeltoe
20
02-23-2023 01:54 PM
ExcelerateRep
10-14-2015 08:20 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
