2000 tl-p
Old Oct 14, 2009 | 01:56 AM
Vman159's Avatar
2000 tl-p
hey guys i am still trying to improve my car anyways i was wondering how come when i hit 4th and 5th gear its like i am hitting a brick wall, as it doesnt pull as good as 2nd or 3rd?
Old Oct 14, 2009 | 02:21 AM
ineedmyfixofacura's Avatar
Getting it Done
that is the horribleness of automatic trannys.
Old Oct 14, 2009 | 02:35 AM
01tl4tl's Avatar
its the gear ratio- 4th is about 1 to 1 and 5th .8 to 1 (examples)
so you are not going to have a lot of torque in them- all cruise is the intent
Make sure your vtec is operating properly, and the TB plate and intake system are cleaned
Old Oct 14, 2009 | 02:44 PM
Vman159's Avatar
oh, if i put on headers will it make a difference in the gears of 4th and 5th
Old Oct 14, 2009 | 02:52 PM
thisisnotdave's Avatar
Porkchop Sandwiches!
Not really. The reason why it doesn't pull in higher gears is physics. The faster something is moving the more energy you use to keep it at that speed. Plus you want to go faster on top of that.
Wana get harder pull in 4th gear? TL-S motor swap is a good start.
Old Oct 14, 2009 | 03:02 PM
Vman159's Avatar
is it worth doing the swap at all, cause look if you have about 200k on your body and you put in 6 speed and new engine arnt you gonna have squeeks and other sounds since its an old car, so would it be better to just sell the car or put in a 6 speed?
Old Oct 14, 2009 | 03:44 PM
If you dont have creaks or rattles now, you wont when ur do the swap. Just cuz you have a ton of miles doesn't make ur car a dude. It all depends on how well its aged. My TL was hit like 1000 times, so by the end of its life, there wasnt shit left LOL. Other people are more fortunate.
IMHO you'll gain more from the motor than the tranny and its less work.
Old Oct 14, 2009 | 03:54 PM
Vman159's Avatar
well the only sound i have is my exhaust banging in the rear cant figure out how to fix it.
Old Oct 14, 2009 | 04:15 PM
Vman159's Avatar
its on bumps and even when i start the car
Old Oct 14, 2009 | 04:51 PM
fsttyms1's Avatar
Now why in the world would you have squeaks and other sounds just by putting that in?
Old Oct 14, 2009 | 04:53 PM
fsttyms1's Avatar
Jack up the car, place it on jack stands and inspect your exhaust hangers (probably a good idea to replace them all due to their age) and make sure none of the heat shields are bent and touching. Also inspect your motor mounts. If its moving that much by starting the car your motor must be moving a lot
Old Oct 14, 2009 | 05:01 PM
Rajca's Avatar
wham bam thank you ma'am
thats what i hate about my tl-s. when i first floored it in my cl-s6 and hit 4th and 5th at wot. i was amazed on how hard it kept pulling to redline (maxed out).
Old Oct 14, 2009 | 05:31 PM
fsttyms1's Avatar
Much shorter gearing in the 6 than the 5
Old Oct 14, 2009 | 05:56 PM
Vman159's Avatar
no i am not saying that just because of the swap u will get squeeks, i am wondering if its just worth all that money about 2k to do a swap... like is it better to just get a new car than put in a 6 speed? dont get me wrong i like my car just wondering.
Old Oct 14, 2009 | 07:20 PM
Rajca's Avatar
true. but they could have made the 5spd gears a bit shorter too seeing how u top out in 4th gear.
Old Oct 14, 2009 | 10:20 PM
Fuel economy. And let me tell you, the TL-S is much more fuel efficient around the city than the CC 2.0T is. And its heavier and has 60 more hp.
Old Oct 15, 2009 | 11:42 AM
Vman159's Avatar
Old Oct 15, 2009 | 12:15 PM
Rajca's Avatar
2k for a 6spd swap, well almost everthing u need, is one hell of a deal
Old Oct 15, 2009 | 02:08 PM
Vman159's Avatar
well that is wat i heard that it os 2k how much is an actual swap cost?
Old Oct 15, 2009 | 02:12 PM
Anotherguy831's Avatar
honestly i paed about 4000 for far for my whole swap (cls 6 motor and trans and little addistions)
Old Oct 15, 2009 | 03:55 PM
Vman159's Avatar
was it worth the money?
Old Oct 15, 2009 | 04:24 PM
Rajca's Avatar
Anyehere from 3.5-5k for a 6spd swap. A bit cheaper if u have thr type s engine already.
And its worht it. The power u get, the control u have,and the uniqueness.
Old Oct 15, 2009 | 04:50 PM
fsttyms1's Avatar
Yes. This is the only way the car should have come. My only regret is i didnt do it 3 trans failures sooner.
Old Oct 15, 2009 | 08:22 PM
Vman159's Avatar
Oh man its good my auto tranny feels strong cause i dont have that kind of money to spend on a failure. If you burn out in the rain does that ruin your tranny?
Old Oct 16, 2009 | 06:38 AM
YES!
Old Oct 16, 2009 | 07:11 AM
Rajca's Avatar
Not really. U have little to no traction on the rain and putting little stress on the trans. Now when u peel out from first to second that will cause more harm.
Old Oct 16, 2009 | 07:28 AM
fsttyms1's Avatar
YES!
Wrong answer. How does spinning your tires on a slick surface effect the 3rd gear clutchpacks shifting thru 3rd?? Thes trannies arent weak. the internal gears are very strong, its a WEAR item (picture it like a round brake pad thats less than a 1/8 thick material) that is what is wearing out from shifts to and from. Your tires will take the most abuse.
Old Oct 16, 2009 | 07:30 AM
fsttyms1's Avatar
actually the most harm would be from 2 to 3 but even then it would be like a normal shift while driving. Probably easier on it since there is less friction and actual stress on the parts if its spinning.
Old Oct 16, 2009 | 12:55 PM
Vman159's Avatar
can anyone tell me the price difference between getting an auto transmition from a dealer or shop and doing a 6 speed swap with or without engine( i dont know if it matters)
Old Oct 16, 2009 | 01:02 PM
fsttyms1's Avatar
having someone (a shop thats willing) do it would probably add 3+ k to the bottom line
Old Oct 16, 2009 | 01:36 PM
Vman159's Avatar
hey guys i need some advice. a friend offered to sell me a 02 tl type s 93k a salvage car, hes selling it for 5k. is it worth changing from tl-p to type s?
Old Oct 16, 2009 | 07:13 PM
DC3328's Avatar
Your Garage
for 5k you can do a type s and 6speed swap and have money left over for mods
Old Oct 16, 2009 | 09:58 PM
Vman159's Avatar
what do you mean for 5 k you can do a swap. A guy is offering to sell me HIS car for 5k (type s)
Old Oct 16, 2009 | 10:02 PM
DC3328's Avatar
Your Garage
... for the 5k that your going to waste buying HIS car to have a stock (salvage title) type s with another glass tranny you can upgrade YOUR car with a reliable 6 speed, type s motor and mods
Old Oct 16, 2009 | 10:17 PM
fsttyms1's Avatar
You will have a salvage title car with the same faulty trans that you will probably still have to replace. For the same 5k (or less if you search good for parts and do the work yourself) you can convert to a type-s motor and 6 speed trans which wont have any failure issues.
Old Oct 17, 2009 | 12:46 AM
Vman159's Avatar
so what would be a good price to sell a 2000 acura tl-p 94k miles salvage title but it was damaged in the rear so nothing big, car has no leaks and no problems.
Old Oct 18, 2009 | 01:12 AM
Vman159's Avatar
Old Oct 18, 2009 | 06:19 AM
Rajca's Avatar
what options do u have, what did u add to the car
Old Oct 18, 2009 | 04:31 PM
Vman159's Avatar
Lol i added bigger exhust tips. but thats it lol. besides that its all stock except 35 % front tint and 20 % all back
Old Oct 18, 2009 | 11:32 PM
Vman159's Avatar
