2000 TL IM swap
2000 TL IM swap
Hi I'm new to the forum but I've been following for a while. I own a 99 TL and I wanted to do a engine cover paint job but I'm not a fan of my current engine cover. Is it feasible to fit a 2000 TL Intake manifold onto a 99 engine with out any modification so I can have the 2000 TL engine cover? Thanks!
J-series addict
Agreed. I'm actually doing this right now to my upper IM. Don't know about pre-99 but 2000 and later used aluminum alloy and it's polishes out quite well. Just get a grinder (must be atleast 3/4hp and spin 12k rpm or more) and remove the safety shield that surrounds the grinding disc. Remove the disc itself as well and put a polishing wheel on instead. Home Depot sells a kit for $20-30 that includes the wheels and also the polishing compound. Make sure the polishing wheels have the same diameter holes as the grinder itself or you can make it fit like it did! Using a torch, heat the surface of the metal to be polished up to about 200 degrees and start polishing unidirectionally. It takes a while but brings out a shine and luster that is amazing. I myself did not remove the paint first and just allowed the polisher to do this part. First time I've ever polished anything and it's turning out to be pretty nice.
Thanks for the advice, but it's not really the manifold I'm after, I wanted the 2000 engine cover cause I wanted to paint it as well as battery cover. I liked the 2000 engine cover a lot better then the one I have but I know id have to switch out the IM too that's why I wanted to know if it would fit.
Received 1,080 Likes
Unfortunately the IM will not fit over the 99TL fuel rails and injectors. To do it you'd have to swap out the entire intake tract (injector bases, fuel rails, fpr, injectors). I replaced mine with the TypeS intake manifold and that's what I had to do.
https://acurazine.com/forums/2g-tl-1999-2003-98/99-tl-types-intake-manifold-complete-600104/
xsilverhawkx
09-28-2015 06:51 PM
