2000 driver front abs sensor
Old Dec 31, 2016 | 08:06 AM
nayborbob's Avatar
5th Gear
Well i destroyed the abs sensor trying to remove it for ball joint replacement picking up a Dorman replacement this am, but wondering about the connector...Does it connect where the wire goes through the sheet metal? My repair manual doesn't explain how/where the connection is made/separated. How Does It disconnect at the sheet metal where it enters the engine compartment? Could not find a diy on sensor replacement anywhere.
Old Dec 31, 2016 | 09:12 AM
01acls's Avatar
The brake sensor unbolts and unplugs in the engine compartment. No need to distroy.
