2000 Acura TL PLEASE HELP IMMEDIATELY
Old Apr 11, 2015 | 08:27 PM
ZigFrom95's Avatar
My acura when I start it up just shakes really hard!! I can switch gears but I can't drive pushing on the peddle does nothing! And it looks like it barely has power to stay on?!? I was just driving it perfectly 10 mins ago. Please what should I do?
Old Apr 11, 2015 | 09:21 PM
Onyxthecat's Avatar
Sounds like a cylinder misfire. If can run the codes, it will tel you for sure.
Old Apr 11, 2015 | 09:40 PM
ZigFrom95's Avatar
I will as soon as possible it started back up and drove home safely but still ... That was very weird
Old Apr 11, 2015 | 09:43 PM
Aman's Avatar
Your Friendly Canadian
Did you get a flashing CEL?
Old Apr 12, 2015 | 09:19 AM
fsttyms1's Avatar
Do you have a Check Engine Light? Was it flashing?
Old Apr 13, 2015 | 04:57 PM
01tl4tl's Avatar
might be coil failure, if it will make it to a parts store they will ck for any fault codes
Multi cyl misfire codes are usually 1 bad coil
any work recently done on the car? that's my first suspect in sudden problems
are you good on the maintenance schedule- spark plugs good and correct 8 dollar each NGK? bs 2 dollar plugs wont last long and will make it run like *%@*
Feb 25, 2020 09:57 AM
Mr.Tea
1/2G MDX (2001-2013)
26
Oct 9, 2015 04:27 PM
MikeYutkin
Sep 10, 2015 10:13 PM
Mike Bertram
Sep 10, 2015 09:27 AM
dlknight
Sep 3, 2015 07:54 PM
