1st time in race track
Old 09-12-2002, 08:54 PM
go-types's Avatar
a bit disappointed about the result in englishtown, nj. anyway, here's the numbers with intake & exhaust & VSA off:
1st(in D5) 2nd(in SS) 3rd(26psi in front wheels & SS)
R/T... 1.191 1.355 0.980
60... 2.390 2.372 2.358
330... 6.479 6.486 6.494
1/8... 9.781 9.806 9.818
mph... 74.31 73.41 73.83
1000... 12.645 12.693 12.700
1/4... 15.052 15.125 15.128
mph... 93.94 92.92 93.13
how can i do better? btw, what's R/T means?
Old 09-12-2002, 08:58 PM
Liquid Ice
LiQiCE's Avatar
R/T = Reaction time, how long it took between the time that the light turned green and when your car's front wheel passes the starting line.
Old 09-12-2002, 09:02 PM
go-types's Avatar
stupid question maybe. so, the 1/4 mile time counted after u passed the starting line or right after the light turned green
Old 09-12-2002, 09:10 PM
Liquid Ice
LiQiCE's Avatar
I dont think your R/T is included in your 1/4 mile time ... Otherwise you would have been alot faster using fully automatic mode versus 26psi+SS which doesnt really make sense...
14.148 with 26psi+SS versus
13.861 with fully automatic ...
I dunno, does that make sense? I'm not an expert on slips though and I've never been to the track, so I could be 100% wrong here.
Old 09-12-2002, 09:19 PM
SergeyM's Avatar
So to get better 1/4 mile results you deflate the tires?
Old 09-12-2002, 09:27 PM
Liquid Ice
LiQiCE's Avatar
Lower tire pressure will increase traction on your tires. For the TL-S you only need to reduce the tire pressure on your fronts since thats where any spinning is gonna occur at launch.
Old 09-12-2002, 10:06 PM
go-types's Avatar
yeah, that's what i thought. however, i just don't know why it came out to be the worst 1/4 time that i did on those runs.
Old 09-12-2002, 10:13 PM
2005 SSM/EB/5AT/Navi
FugittiveTLS`03's Avatar
How long in between runs?? if your sitting there....raise your hood let the car cool off some.
BTW........ I usually deflate to around 17-19 psi.......but don't forget to put air back in them before you leave to go home......We don't want any ACCIDENTS!!
Old 09-12-2002, 10:16 PM
O.G.
BlackShadow's Avatar
I hope you know that the hotter the weather the slower your times will be. An engine performs much better and faster in nice cold air like under 60 degrees. But the colder, the better. It also depends on the humidity, altitude, weight of your car (was the spare tire in, do you have a system, rims, etc...). And of course, your R/T. Since this is your first time at the track, your times will suck until you get better at launching it. There are a bunch of TL-S running in the 14s so don't worry. Eventually, you'll get there.
Old 09-12-2002, 10:35 PM
Really those are not bad times for being your 1st time at a track.
15.0 is very respectable for 1st time but............you need to work on your R/T .50 i believe is a perfect light.......my best is .709
but still good job!!!
Old 09-12-2002, 10:37 PM
go-types's Avatar
probably around 45mins in between each run.
Old 09-12-2002, 10:54 PM
Raise the hood man!!! 45 min is a long time. Engine should be nice and cool by the time you get to the line!!
Cooler car=better times!!
Old 09-13-2002, 12:45 AM
still a Masshole
ferizzo's Avatar
Go, those are pretty good times. I did a 15.2 best about a month back all stock. go when the weather is cooler and you should be in the 14.9s!
Old 09-13-2002, 01:02 AM
Comptech Freak
samkws's Avatar
fully auto should be faster than SS....especially if u put it in D3
Old 09-14-2002, 02:21 AM
Acura TLS are SLOW
MotionEffects's Avatar
i ran a 14.7 stock, no mods at all. but the temp was around 45-50 degree and hummid. was low. lower the tire pres. to 19 psi with VSA off and gate shift @ Atco Raceway
Old 09-14-2002, 07:30 AM
ChucksCL-S's Avatar
GoTypeS Don't worry about your reaction time. The clock starts when you trip the beam. R/T is usful to guys racing in their own classes and have to leave really close to green to win. If two equal cars are racing usually the guy who can leave first will win, and by 1 or 2 1000ths of a second isn't all that uncommon. Just watch any NHRA pro stock race to see this. There, leaving is everything, after that it is up to the car pretty much. For your best times, leave on green, minimal tire squeal, cool day, cool engine, synth. oil, no spare or anything in trunk, low fuel level, manual shift D1 D2 D3 or just leave it in D3, VSA off. Also Climate control off. That should give you the 14's.
Old 09-14-2002, 10:01 AM
numbaonexstunna's Avatar
my best r/t was .5 ..just floor it when its on last yellow. ran a 14.7 with just intake...i need to run it again now that i have my v-afc, pulleys, and exhaust
Old 09-14-2002, 07:23 PM
Got_3.2?'s Avatar
go typeS
how much was it to run at the track? i was thinking about running my stock TL there but wanted to find out more info before i went for my first time.
thanx
Old 09-15-2002, 12:09 AM
go-types's Avatar
Originally posted by got_3.2?
go typeS
thanx
$20 for racing, $3 for a permanent number & $3 for a helmet.
Skirmich
09-15-2015 06:41 PM
09-14-2015 03:16 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
Quick Reply: 1st time in race track
