1999 Acura TL with Idle Problems
Old Jun 10, 2014 | 02:44 PM
MATTHEW_CAVANAUGH's Avatar
I have recently jump-started a 1999 Acura TL 3.2 that has not been started in 12 months. The vehicle has 270,000 miles on it and ran perfectly the last time it was started.
When I started the car today, the engine runs very smoothly and strong (not rough) but the idle cycles continuously, on its own, from 1000 to 2500 RPM (it did this continuously for over 20 minutes). When I rev the vehicle as high as it will go, it peters out at 5000 RPM and falters. When I put the vehicle in DRIVE, the idle problem goes away and it holds very steady and smooth at 1000 RPM, and with the brake on, will rev strongly.
Any advice on the idle would be greatly appreciated. Thank you!
Old Jun 10, 2014 | 04:00 PM
Nicks2001tl's Avatar
Welcome to Acurazine!
If idle is fluctuating it can be narrowed down to the IACV valve under the throttle body. It most likely just needs to be cleaned.
Old Jun 10, 2014 | 06:28 PM
3.2TLc's Avatar
Yeah, an older car sitting for a year and not run....can be a problem sometimes.
~ Fresh premium fuel with a cleaner such as Seafoam will help the octane.
~ Make sure that all fluids and the battery are good.
~ Cleaning the TB intake, EGR passageways and IAC valve will help the idle smooth out.
~ Check the coolant's level in the rad and inspect the plugs.
Old Jun 10, 2014 | 09:35 PM
01tl4tl's Avatar
what these guys mean is remove the throttle body assembly from car
on its bottom is a cover and inside the IACV- it clogs and does exactly what you describe
no need to buy an expensive new one when carb cleaner will cure the problem
welcome to azine-
Old Jun 14, 2014 | 11:25 AM
ErickUa5's Avatar
Mr.Helpful Diagram
After the cleaning is done try the idle relearn procedure, it worked for me on a few Hondas.
Old Jun 15, 2014 | 04:18 PM
01tl4tl's Avatar
leave a TL sitting for a year and its going to harden the crud blocking small air slit in the IACV, screwing up idle
5000 is the rpm safety limit when in P or N
remove Throttle body assembly and small round cover on bottom, iacv is in there
see diy section for detailed help
Old Jun 15, 2014 | 04:19 PM
01tl4tl's Avatar
good call on the idle relearn Erik,,I forget about that
Zonian22
Nov 14, 2015 01:20 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
NSolace
Sep 3, 2015 08:02 PM
