18" Rims on Type S
18" Rims on Type S
Will 18" rims fit on a stock '03 TLS with no rubbing or size issues? I want to get larger rims but am wondering about how they will fit on the car. Any info will be greatly appreaciated.
TL-S driver
yes they fit as long as the offset is at least +45. +48-50 would be best. you'll need to cut the tabs with +45 offset. the tire should be, 225/45 to keep everything in spec
you will need to focus on offset AND rim width; tire size and amount of lowering will matter too.
"generally"...
- 7.5" wide rim needs at least a +45mm offset for 225mm tires; something higher if using 235mm
- 8" wide rim needs at least a +50mm offset for 225mm tires; might be ok for 235s
there is a lot of info in the tire/rim forum.
"generally"...
merc009
10-03-2015 12:59 AM
